-   -   Sun Visor Fix -How To- (http://www.jeepforum.com/forum/f12/sun-visor-fix-how-1607617/)
Gage56 09-20-2013 08:57 PM
So yeah i thought this might help some people out
I was tired of my broken drivers side visor, i look all over and just could not bring myself to pay $$$$ for one Because im a Cheap A$$ SO I Fixed it Like So,
All the visor is made up of is a piece of masonite and a tube with 2 bars in it
start with removing the thread from around the vinyl
http://i18.photobucket.com/albums/b1...ps98895cdc.jpg
you only need to remove a little bit once this is done burn the end of the thread to keep it from pulling out any farther
once you have the binding undone you can pull the 2 bars out of the assembly. Once you have them out spread apart the vinyl and remove the the tube and piece of masonite
http://i18.photobucket.com/albums/b1...pscdfcf7df.jpg
From here its pretty simple remove the staples from the tube and keep ahold of them
http://i18.photobucket.com/albums/b1...psabff1043.jpg
http://i18.photobucket.com/albums/b1...ps09661e67.jpg
Get a piece of masonite or in my case i used paneling as i had it laying around and it was the right thickness and trace a pattern
http://i18.photobucket.com/albums/b1...ps6a269d0d.jpg
http://i18.photobucket.com/albums/b1...ps7532486b.jpg
Cut it out and get ready to reattach the metal to it
http://i18.photobucket.com/albums/b1...ps15d64dfd.jpg
Here i used a 1/16" drill but and made new holes for the staples
http://i18.photobucket.com/albums/b1...ps62d76450.jpg
http://i18.photobucket.com/albums/b1...ps43e62778.jpg
I also added some body panel glue just to be sure
http://i18.photobucket.com/albums/b1...ps28407f31.jpg
Now line it all up and push the staples through and then clamp it tight till the glue dries
http://i18.photobucket.com/albums/b1...psca8cd18e.jpg
Once the glue has set remove the clamps and flip it over to hammer the staples flat
http://i18.photobucket.com/albums/b1...ps42ca0f16.jpg
Now slide the whole assembly back in the vinyl sleeve
http://i18.photobucket.com/albums/b1...ps294ae0cf.jpg
http://i18.photobucket.com/albums/b1...ps80983b92.jpg
Now get your choice of thread and needle and re stitch the binding back up
http://i18.photobucket.com/albums/b1...ps225bee10.jpg
Slide the metal caps back on and you are good to go
http://i18.photobucket.com/albums/b1...ps1b04c2b4.jpg
http://i18.photobucket.com/albums/b1...pscb28c70a.jpg
http://i18.photobucket.com/albums/b1...ps797ecc83.jpg
On a side note i did add some grease and i did pry out on the tube a little bit to make the bars move easier
Hope this helps some of you out :cheers2:
timatoe 09-20-2013 09:43 PM
That's a good write up there.
DirtKar 09-20-2013 09:57 PM
Well done, Sir. :thumbsup:
SeanB95YJ 09-20-2013 10:04 PM
as an alternative, you could also use sheet metal (steel or aluminum) or plastic (vinyl, HDPE, lexan, etc) as an alternative to the masonite that would be more resistant to possible future damage from water.
thanks to your thread, I might just disassemble my visors to remake them with a bit more of a "wing" towards the center to block the sun that always seems to send that laser-like beam over the rear-view mirror straight to my retina LOL
GrantYJ 09-20-2013 11:35 PM
Nice post!
It's nearly impossible to find driver's side visors that don't have this issue.
Tom95YJ 09-20-2013 11:41 PM
2 Attachment(s)
Nice post, I need to do this !
I have added a hyperlink to this thread in the super modifications sticky
Louie4 09-21-2013 08:29 AM
Very nice good sir. I wish I would have been that smart when my visors had broke years ago. Instead I threw away my drivers side and put the pass. side on the drivers side...dumb.
Gage56 09-21-2013 01:49 PM
Thanks Gent's
Just trying to help out :thumbsup:
Gage56 09-22-2013 01:10 PM
Woot I Got stickied :rofl:
Tophog1 01-02-2015 12:21 PM
Nice post. I just used it to fix mine.
But after seeing your restitching job compared to mine, I think I'll keep my day job! :rolleyes:
JeeperDon 01-03-2015 06:11 AM
1 Attachment(s)
Sun visors are the interior version of track bars. I haven't had any of either in a dozen years. If you must, a baseball cap is an infinately adjustable sun visor. Wear it in the conventional manor, not like this dolt. :cheers2:
warthog312 01-03-2015 09:24 AM
Agreed. I really never leave the house without my sungl***** anyway.
Well, that's a Cubs fan for ya! Go White Sox!
Opihi59 01-03-2015 11:56 PM
If you come across a TJ visor, you can use your hardware on it and put it in your YJ.......
TJ Sun visor mod
JWELK 01-04-2015 04:57 PM
Thank you: My passenger side is bad.
The time now is 06:57 AM.
