Suggestions: Best Dana 60 axle swap for my 93 YJ - JeepForum.com
post #1 of 6 Old 01-25-2011, 07:35 AM Thread Starter
Dwayne93YJ
Dwayne93YJ's Avatar
I need some opinions/advice on what you guys think is the best Dana 60 swap for my 1993 4.7 Stroked YJ. I still run a stock manual transmission, 35" Tires, total of 7" of SUA lift (once I swap, I may go SOA), and 4.56 gearing. I dont do a ton of off roading, but when I do I want to be prepared. This is my DD. Please let me know what you guys suggest to look for and what I should expect when installing them. Researching on JF and the internet, it looks like my best bet is a kingpin front (not sure what year is best) and a 14 bolt rear. Thanks guys.
Dwayne
Dwayne93YJ is offline
post #2 of 6 Old 01-25-2011, 08:22 AM
dan240
dan240's Avatar
If you're staying with the stock transfer case you're going to need a driver side drop front out of a Ford. Most would say the best year would be 78-79 because there is quite a bit more room on the driver's side to weld new perches on....there are probably other reasons as well that I am unaware of...
I assume you're planning to run a much bigger tire than a 35. A 14 bolt is a boat anchor and even shaved that thing is going to drag on everything with that small a tire.
If you are sticking with 35's I'd build a HP44/9" or a HP44/8.8 combo.
1994 YJ 4.0L 5spd
SOA, 5100 Bilstein, TJ Flares, 35" BFG AT, 8.8, SYE, D30 truetrac/chromo, 1" MML
dan240 is offline
post #3 of 6 Old 01-25-2011, 08:26 AM Thread Starter
Dwayne93YJ
Dwayne93YJ's Avatar
I don't plan on going with a bigger tire, so that said any specific HP44/9" or 8.8 that I should look for? I want to have disc brakes and any other "upgrades" that I can. Thanks for the information.
Dwayne
post #4 of 6 Old 01-26-2011, 01:13 PM Thread Starter
Dwayne93YJ
Dwayne93YJ's Avatar
bump
post #5 of 6 Old 01-26-2011, 01:20 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Dwayne
The best Dana 60 swap is a 78-79 F350 front. most desired year and model. almost any ford Dana 60 will work, you just need to outboard the springs with some plate. depending on your skill level, that might be simple or impossible.
if you need a 60 in the front you most likely want a one ton rear... Sterling 10.25, 14 bolt, or Dana 70. All are strong.
-14 bolts are a dime a dozen with an extra pinion bearing. Its hard to find anyone that has broken one, even on 44's. they are big
-Sterling 10.25 are strong and smaller than a 14 bolt. parts are easy to get but not as much as the 14 bolt. not as common but a good axle
-Dana 70 - I know little about them besides they are big and strong.
edit - side notes.
1.you can go Dana 60 rear and still have some clearance with your 35's. not as much as a Dana35. if you are only running 35's it will be possible but hard to break a set of 60's.
2. Search and read. google is your friend.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #6 of 6 Old 01-26-2011, 01:51 PM
WhyYJ
I am currently building my Jeep on 1 ton axles. Well I should say 1 ton front and 3/4 ton rear. I am using a 79 Ford F350 Dana 60 (can also be found in some F250's) I went with this axle because I am staying SOA in the front for now and it is nearly a bolt in mod. If you are going to link it, it is still the more sought after because of the reasons listed above. I am going to be running 39.5 Iroks for now . If I ever go bigger I will put a 14 bolt in the rear or modify my rear for 35 spline axle shafts. I like the extra clearance you get with the 60.
As stated above there is a TON of info out there on this swap.
WhyYJ is offline
Looks to do an axle swap...suggestions? Blstr88 YJ Wrangler Technical Forum 13 09-04-2010 05:35 PM
Suggestions for axle swap on 95 YJ 4lowherewego YJ Wrangler Technical Forum 9 05-24-2010 07:30 AM
Rear axle swap suggestions? rollcage TJ Wrangler Technical Forum 1 12-01-2009 06:05 PM
Suggestions for dana 44 swap. diamonddave TJ Wrangler Technical Forum 2 09-15-2008 09:58 PM
Dana 30 axle shaft spline options, suggestions snowrydr01 TJ Wrangler Technical Forum 9 07-01-2008 08:55 PM
