so i was out wheeling last weekend and im pretty sure i blew out my rear main seal. leaked a bunch of oil and even sucked in some mud into my oil pan. After i got it back home i replaced my rear main seal, bought a new oil pan (mine had some nasty looking dents anyway) and a new oil pan gasket. tore it all apart put it all back together with the new stuff and it still leaked at the back of the oil pan. took it apart again and put a new oil pan gasket on and just cranked it up and its still leaking in the same spot. Tomorrow im gonna try it yet again and this time buy another new rear main seal too. I was wondering if yall have any other suggestions or tips where you think i could have gone wrong, because i really dont want to take it to a mechanic that just feels like giving up haha
when you put on the rear main seal, did you make sure the "lip" was facing the FRONT of the engine? Get a friend to help line up the oil pan with the gasket when bolting it up, it makes it much easier. Do not over tighten the oil pan bolts, this will ruin the gasket as well, 7-11 ft lbs
Is it leakin from the seal area or is it leaking from the pan gasket surface?when the pan is off you should lay the pan on a flat surface .Then with a ball peen hammer, lightly peen or hammer each bolt hole "gasket face side" to remove the convex shape it has from the last install and torquing. peen them flat or just lightly concaved.If they are deformed they will bottom out before completely compressing the pan gasket .just a useless knowledge tip.
The best I have found for a flat piece to lay a item on is a piece of glass for flatness.
It does not take much to make you oil pan or valve cover not flat. One bolt over tightened, or under tightened will do it.
By the way, I sort of doubt that you sucked in mud, so if you found mud looking sludge in your pan you may also find it in your valve cover. May be time for a engine cleaning!
RTV is very good, although if you are thinking about the future and the next time that you take it apart. You will want to think about how much you are using. The rear end is easy to clean RTV. The oil pan not so much.
Never had any issues with removing and or cleaning any surface that had rtv or other sealer on.Just have to work at it . Right tools are the key .It is a little tedious but America wasn't built in a day! You still haven't told us if its the rear main leaking or the pan gasket. Rear 2pcs seals are not as easy as one may think for replacement. One piece seals are a breeze . So whats the leak info rear main or pan gasket area.if you have old patches of pan gasket left on the block with out rtv it probably wont seal up again. Apply the sealer to pan and block area then assembly . follow manufacturer directs on flash/ set time for the sealer before assembly .good luck hope for a positive post from you tomorrow.
hey thanks for the help but im pretty sure its the rear main, and there was defenitly mud in the old oil pan. However i still cant get everything to seal up and ive tried three times now. Im gonna take it to a mechanic sometime this week
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
