Quantcast SUA HPD30 axle truss follow along - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > SUA HPD30 axle truss follow along
GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp SeriesRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 08-15-2009, 12:14 AM   #1
Joe Dillard
Free clues & suggestions
Joe Dillard's Avatar
Some time ago, a couple friends came over & dropped off a donor SUA HPD30 axle so I could use it to fab up an axle truss. My time & motivation to get it done has been lacking lately with work, kids etc pulling me away, but I found some time yesterday to make at least some progress.
I started things out by going to my local steel supply shop & picking up a piece of 1/2"x5"x6' flat plate rolled mild steel, and a piece of 1.25" round tubing that I'll integrate along the top edge of the truss for added strength & cool factor.
Here's how the rough draft cardboard template cutout looks. I'll be making some modest alterations to it as I go along so as to have a better fit along the axle mounting surfaces.
Here's the initial shape along the vacuum disco housing - however, there will be some modifications to the plate so that it rests against the housing closer.
Rough trace along the plate steel:
Experimenting with a guide plate used for plasma cutting.
Initial cut:
Well, that's all the pics I have of it as of now - hopefully tomorrow I'll finish it up. We'll see.
Joe Dillard is offline   Reply With Quote
Old 08-15-2009, 12:38 AM   #2
91YJRockCrawler
looks good... you need to build me one
91YJRockCrawler is offline   Reply With Quote
Old 08-15-2009, 12:49 AM   #3
Joe Dillard
I just so happen to have enough material to build two.
Since you are probably ~1.5 hours drive away from me - you are welcome to swing by tomorrow & we can build you one.
Old 08-15-2009, 01:13 AM   #4
ImpactFabWorks
Looks good joe. I'm always impressed with the things you fab up. I used to have access to everything I would need but the economy ended all of that for me. I have been looking g to build a lotnog stuff and I do have the skill and experiance to actaully do it. But hey eventaully I'll get a shop put together
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
www.Impact-FabWorks.com
Impact-FabWorks Facebook
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline   Reply With Quote
Old 08-15-2009, 01:22 AM   #5
Joe Dillard
Thanks. I wish you the best at getting things going again. I can certainly understand how things can go sour, especially in todays economy.
I too, use to do modest fab work for a living in a shop to die for....many years ago. Sure was lots of fun - but often hard work at the same time, especially in the heat.
Does it ever get hot out there in Victorville?
Old 08-15-2009, 01:35 AM   #6
ImpactFabWorks
just alittle hot. Last summer I was building a trophy truck for a shop out here and it was like 112 degrees all summer. I was not happy in my hood and welding jacket. It was be really hot or get burned by falling sparks.
Old 08-15-2009, 01:54 AM   #7
Joe Dillard
You should join us whenever we start going to Johnson Valley again later this year. Or do you already have a group of wheelers you go with to JV?
Old 08-15-2009, 01:59 AM   #8
ImpactFabWorks
I have a guy that I have gone out there with a few times but I haven't talked to him in a while. Never been out there with more than about 3 or 4 vehicles. But, I have to get a new chain in my transfer case before I get to go anywhere
Old 08-15-2009, 02:06 AM   #9
Joe Dillard
Yea, we usually have ~4-8 Jeeps, but sometimes a couple more.
Most I ever recall having on the trail at the same time was ~15. This was mostly due to us having a yearly Rookie Run we do which has a few newcomers join us. We stagger the Rookies between us & run SledgeHammer as an opening trail.
Old 08-15-2009, 02:11 AM   #10
ImpactFabWorks
i haven't been able to finish sledge hammer yet. I went in the spring and broke an axle shaft. we usaully do bull frog.
Old 08-15-2009, 02:30 AM   #11
Joe Dillard
I don't recall doing Bull Frog. Perhaps I will sometime.
The guy in the blue TJ is a friend of mine (Jon of winchline.com)
http://rubiconscat.com/Hammers/08/JackSledgeBFrog/BullFrog.html
Old 08-15-2009, 02:38 AM   #12
ImpactFabWorks
good video. and a couple very nice jeeps. i have to admit even i will sound like a wuss, i have taken a few bypasses on that trail. i just don't feel like my jeep is ready for the whole thing yet
Old 08-15-2009, 02:46 AM   #13
91YJRockCrawler
if i had a rear axle under my jeep right now and money ... i would love to
but thanks for the offer
Old 08-15-2009, 03:55 AM   #14
Joe Dillard
It's better to know where to draw the line, than to knowingly get in over your head.
Old 08-15-2009, 04:01 AM   #15
Joe Dillard
You wouldn't *have* to bring your Jeep - or spend money for the truss.
I need to build a few prototypes anyway & I can not use this design on my POS since it's SOA.
Simply show-up & leave with a truss. I could weld it on at a later time/date.
Glock Forum
