sua in front soa in rear? - JeepForum.com
post #1 of 7 Old 01-20-2010, 07:00 PM Thread Starter
Mikerp97
so i just bought my self an 8.8 for my jeep (dana turdy five finally went) well iam prob going to order MORE's Ford 8.8 Install Kit and i read how its mainly used for soa, i was thinking can i just leave sua in the front and go soa in the rear? i have 4 inch springs front and rear and iam figuring kkeeping 4 inch spings in front and use my old stock springs in the back for the time being
owers of:
91 jeep wrangler sport 2.5L 4" rough country lift, 3 inch body lift, 35x14-15 ground hog tires, smittybilt XRC-8 winch, dana 30 front, ford 8.8 rear welded
Mikerp97 is offline
post #2 of 7 Old 01-20-2010, 07:01 PM
jeepinmichguy_
rear will sit higher by a lil bit, just put a lift shackle on the front to level it out.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
post #3 of 7 Old 01-20-2010, 07:09 PM Thread Starter
Mikerp97
yeah thats what i was thinking has anyone ever seen this done? have pics maybe lol?
owers of:
Mikerp97 is offline
post #4 of 7 Old 01-20-2010, 07:24 PM
kloppk
I ran my 8.8 SOA and the front SUA for a couple of years.
Just be sure to install an anti-wrap bar on the 8.8.
I tried to run without one but quickly wrapped the stock springs and damaged by rear CV DS. Expensive lesson.
The longer shackles up front for leveling are somewhat of a pain as they catch on rocks easier that stock shackles. Bent 1 front spring due to them being long.
A couple of pics of it with the SOA & SUA setup.
Tacking the MORE perch's and modified shock mounts on the 8.8
A couple of seasons later the D30 went SOA..
Went with the Rocky Road YJOTT high steer setup...
(Not the actual springs used in picture)
Moves tierod and drag link way up over the springs and away from the rocks
kloppk is offline
post #5 of 7 Old 01-20-2010, 09:24 PM
BackRoadJPin
1995 Wrangler
BackRoadJPin's Avatar
guy back in Utah had this setup, but it was SOA Front / SUA Rear it has it's benefits and seemed to suit him well. I will see if I can find you a link to his information.
With 4" lift springs you might be one of the lucky ones that is able to use the stock 8.8 SUA perches. What year 8.8 is it?
Back Road Jeepin
BackRoadJPin is offline
post #6 of 7 Old 01-20-2010, 11:09 PM
BackRoadJPin
1995 Wrangler
Ok it took some time, but I finally tracked down the guy in Utah and it is actually SOA Rear, SUA Front it works, he wheeled the crap out of it, but has since sold it and is building a hot rod I think and all of his pictures are gone from the BB...
Back Road Jeepin
post #7 of 7 Old 01-21-2010, 10:48 AM
RockWoRM
RockWoRM's Avatar
just throwing out my
I'm not really sure what big advantage there would be to an SUA/SOA combo. Most do it the other way around. You would need (should have) a trac bar for the rear for it to be done right.
Seems to me most of the flex advantage of an SOA set up would be in the front to better negotiate obstacles... the rear just sorta follows... if you get my drift.
Anywho, just the way I see it.
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
3.07 rear Trac-Lok to 4.10 front and rear. To-do next. RUNIT TJ Wrangler Technical Forum 9 01-31-2008 08:14 PM
what about d30 front and d44 rear? adamhendrickson TJ Wrangler Technical Forum 6 11-25-2007 05:05 PM
Is Sahara Dana 44 front and rear or just rear? Capinsano3 TJ Wrangler Technical Forum 27 01-31-2007 01:03 PM
front AND rear end in YJ demoguru YJ Wrangler Technical Forum 2 11-11-2006 01:28 PM
rear 35 to front 35 Jeepguy3401 YJ Wrangler Technical Forum 3 03-04-2002 10:59 PM
