Stupid stupid stupid Hi Lift question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Stupid stupid stupid Hi Lift question
All viair onboard air systems ship free to lower 48! Www.Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFF
Unread 04-22-2006, 04:26 PM   #1
Ichytriggrfingr
Ok, so, I just bought my very first HiLift jack, and to test it out, lifted up the rig from the front bumper. Now I can't get the thing to lower the Jeep back down. I'll just say, I've never even seen one of these things used before, even though that is not a real defense.
So, the little lever is in the down position, but moving the handle up and down isn't doing anything. Is it somehow bound up? And should I just use another jack to take the load off and lower the vehicle?
Ichytriggrfingr is offline   Reply With Quote
Unread 04-22-2006, 04:37 PM   #2
jipjip
push the handle as far down as it goes, and it should click,the as you let the handle come back up, it will lower the jeep one click of the high lift. DO NOT LET GO OF THE HANDLE. this is one reason they are dangerous. if you let go, the handle will shoot back up and hit you in the chin (talking from experience).
good luck.
95 yj sahara green w/ spice hard and soft top, bikini top,full steel doors, and 2 piece bestop soft doors,tnt customs front tube fenders w/ 6" flare,warn gas tank skid, skidrow oil pan skid,4.0HO,rear 31 spline 8.8 w/ disc brakes,4.10's and lsd,front HP d30 w/ 4.10's and aussie front locker,ax15,np231j w/ jb conversions ss sye, tom woods custom cv d/s,RE 4.5xd,35" toyo open country m/t's, 1" daystar body lift, warn 9.5ti
jipjip is offline   Reply With Quote
Unread 04-22-2006, 04:46 PM   #3
Ryanpowell167
And it isnt going to be a little sissy hit either. It will BADLY BRUISE wherever it hits. Its supporting the weight of the vehicle you know....Its helps to lube up the pins sometimes because they jam alot and it takes a little but to get them to pop out. Ive thought about getting a little bit stronger springs for it but i dont think the benefits are really worth it...
Black 1992 wrangler, 40" creepy crawlers, d60/14b 350tbi/700r4/np205, spring over on 4" springs.
2011 Ford F-150 Raptor, whipple supercharged...
Ryanpowell167 is offline   Reply With Quote
Unread 04-22-2006, 04:47 PM   #4
Ichytriggrfingr
Nope, pushing it down doesn't cause it to click at all. The carriage move about an inch up on the rail and then stops. Return the handle upright doesn't seem to engage the steping mechanism at all. It doesn't look like there are any parts that would be candidates for clicking at this point. Everything seems to be settled at its bottom most point, if that makes sense. I don't see any of the spring op rods that would be moving.
Good news is that the steering seems to be a little tighter now. Man i feel like an idiot.
Unread 04-22-2006, 04:48 PM   #5
Ichytriggrfingr
I'll try the lube
Unread 04-22-2006, 04:54 PM   #6
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
or be lazy like me and just crank the jeep up and drive over it....
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS!
Big-n-Broke-YJ is offline   Reply With Quote
Unread 04-22-2006, 04:57 PM   #7
Ichytriggrfingr
Well good. I'm not incompetent. Just stupid. The lube did the trick. Good ol PB Blaster.
Yeah, the first direction in the instructions? Properly lubricate all the parts.
Unread 04-22-2006, 05:01 PM   #8
Ichytriggrfingr
HAHAHAHAhA, Yeah, I almost did that, but didn't want to destroy the concrete at this place the first week I move in. It already has red paint scraped all over it from me losing my temper with the jack!
Unread 04-22-2006, 05:05 PM   #9
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
yea i mean it's not safe but you can make do sometimes if need be.
my hi-lift gets jammed up sometimes (too lazy to lube it but i guess i will next time i need to use it) and i've gotten into the habit of just pushing the jeep sideways by hand if i have it jacked up on the front or back or driving the jeep if it's jacked up from the side.
as long as you think first about what direction to go you can minimize the risk of damaging your body
-Erik <--- also always does this in the grass.... concrete might damage the jack
Unread 04-22-2006, 05:05 PM   #10
Ryanpowell167
Or just do like i did acidently and forget to put the parking break on and watch it roll backwards off the jack. Luckily the tires were only a few inches off the ground(still alot because i have 4" of lift!). ROFL it started moving back, and i was all pulling on it and it just quietly rolled off and stopped. I put the e-brake on and went in and sat down for the rest of the day.....
Unread 04-22-2006, 05:08 PM   #11
Tom95YJ
[ ] Lights Do It Better
Tom95YJ's Avatar
good luck.
Deff. hold onto that handle I watch my buddy let go of his handle and it came up and broke his jaw in 2 places
'88 YJ Daily Driver Build Thread
'98 TJ Built & Sold
'95 YJ Built & Sold
'99 XJ Black Betty Build Thread
Utah Jeep Crew #164
NAXJA Member #4115
January 2013 Cherokee of the Month
Tom95YJ is offline   Reply With Quote
Unread 04-23-2006, 12:18 AM   #12
jipjip
ooooooooouuuuuch, yep that beats mine. i was just a badly bruised chin, and pride. i'll tell you what though, you'll never see me w/o gloves, and my head out of the way. i usually use it standing at the side of the handle now, so if i slip, it doesn't touch me, and the gloves help to make sure i don't slip.
