STUPID JEEP + STUPID OWNER = Problems - JeepForum.com
post #1 of 45 Old 08-28-2007, 08:03 PM Thread Starter
toomanyjeeps
So, I got the TPS replaced the other weekend. I went to start up ye’ ole’ Wrangler and the POS is back to running like garbage again. WTH!!!! Is going on? I am thinking ECM. Either that, or some sort of short between the battery and the ECM (which would be easier to understand). It is as if the car is just STUBBORN and won’t retain anything that it has learned. As soon as the key goes off, it goes back to being a heap again.
Any ideas would be greatly appreciated. Obviously, it is going back to the dealership that serviced it first thing tomorrow, and I am not paying another penny.
toomanyjeeps is offline
post #2 of 45 Old 08-28-2007, 08:58 PM
jeepinMatt
jeepinMatt's Avatar
there is also another sensor called the IAC= idle air control and explain what running like garbage is????? low idle??? rough, too many to list. Not to mention the jeep is um around 13 years old its not a brand new lexus off the lot, you might have to work on her a little
jeepinMatt is offline
post #3 of 45 Old 08-28-2007, 10:21 PM
flame0086
Running like garbage doesn't help us out. What exaclty is it doing?
Also, I thought we told you not to take it to the dealership But, if I were you, I would taking it back also, since they didn't really fix it.
Now, if you want to take our oponion and compare it to the dealer, that is fine.
100 mpg!! Western Washington Univeristy X-Prize Team
Support Search and Rescue
Get Lost
flame0086 is offline
post #4 of 45 Old 08-28-2007, 10:26 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
ahhh the ecm "learning" stuff argument again....
i'll stay on this one....
you do need to be a LOT more specific though, if you expect help......
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #5 of 45 Old 08-28-2007, 10:30 PM
flame0086
Trust me, I'm going to go there again.
Get Lost
post #6 of 45 Old 08-28-2007, 10:57 PM
goatboy
Yer only choice after last weeks miserable performance on this forum is to take it to the dealer...period...let it be their problem...you were singin' their praises then, maybe they can recalibrate the pcm again. Eh?
goatboy is offline
post #7 of 45 Old 08-29-2007, 12:47 AM
dansegroves
check your grounds.
Dan tha Man!
93 Wrangler Sahara..I-6, 5 speed, 4.10 gears, ford 8.8 rear, dana 30 front, 32x11.50 pro comp mud terrains, tolly fab tube fenders, and more to come...!
TULSAOFFROAD.COM
dansegroves is offline
post #8 of 45 Old 08-29-2007, 12:49 AM Thread Starter
toomanyjeeps
Ok, I get it, I got it then too.
I took it to them and when I left, 99% of the engine problems were gone. Gas mileage was back, it stopped sputtering when from 1000-2000 RPMs, and it didn’t even come close to stalling when it was at idle. It has TONS of power, no weird engine noises. The reason that it went to the dealership, was because I tried stuff myself and it didn’t work and then I took it to a few other people. I UNDERSTAND where I made the mistake and the fact that I could have done it on my own. The problems, which are rather listed above, were rough idle, backfiring, hesitation between 1000 and 2000 RPMs when speeding up (or jumping), poor gas mileage, then JUMPING when shifting out of first. I took it to them, they did what they do – and when I left, I couldn’t tell the difference between that and my TJ. It handled beautifully. It sat for about 4-5 days (to top it off I broke a bone in my hand), then when I went to start it, all the problems were back again.
It is definitely going back tomorrow just because it is still supposed to be running like it was when I left, and it isn’t’. I get what everyone is saying though. All right? I can’t exactly apologize for taking it there. I was getting fed up with the Jeep in the first place. But now I know.
As for the whole “singing their praises comment”, what else could I do? I was HAPPY, sorry that is wrong. After buying this thing and dumping countless hours into it, etc……….it was finally to the point where the engine problems were completely gone for a period of time. Moreover, I did take everyone’s opinion. I didn’t pay attention to myself CALIBRATING (adjusting – whatever), like I should have done. When the individual the other day was talking about turning the TPS until it reads properly so that the engine idles normally. So far, it has a new TPS, CPS, IAC, and Knock. It just doesn’t (for lack of a better word); seem to know how to use it all. In addition, if it learns, it forgets. It ran beautifully, and now it is back to normal (normal being bad).
post #9 of 45 Old 08-29-2007, 07:51 AM
Jesse-James
Jesse-James's Avatar
1989 XJ Cherokee
Sounds like someone needs to sell their Jeep and buy a Honda.
Live in SE WI? ----->
Jesse-James is offline
post #10 of 45 Old 08-29-2007, 10:16 AM Thread Starter
toomanyjeeps
Jeeps, Jeeeepssss, as in more then one. I wonder if I can get a good deal this time of year on a truck.
post #11 of 45 Old 08-29-2007, 11:06 AM
Howard94yj
To many jeeps.....
Mine does the exact same thing you are talking about ... If you ever figure it out let me know!!! I have tryed everything. But I will not take it to a dealer!!!!
Howard94yj is offline
post #12 of 45 Old 08-29-2007, 11:59 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
I was almost gonna forgive you till you threw that in.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #13 of 45 Old 08-29-2007, 12:13 PM
newYJfan
i'm not sure what i just read, though it seemed informative
*me/ hugs my carb'd & nuttered YJ
good luck with your problems though, they (needless to say) seem like a huge PITA
-- 1990 YJ, 4.2 Manual, nuttered, vac-hose minimum
-- my name is Josh
-- my jeep's name is MacGyver
-- "newYJfan"... whoops, didn't think about a good username
newYJfan is offline
post #14 of 45 Old 08-29-2007, 12:30 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Yea, don't expect any more advice with that atitude.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #15 of 45 Old 08-29-2007, 01:13 PM
giggityjeeper
when mine started spitting and sputtering at low RPMS, it ended up being the dist, and 1 wire was bad....
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
Exhaust guard? stupid stupid stupid mrcrwly JK Wrangler Technical Forum 10 05-15-2009 04:44 PM
Stupid Jeep Carb problems icelandismine YJ Wrangler Technical Forum 16 12-09-2007 04:33 PM
New owner, Stupid question gravely_todd JK Wrangler Technical Forum 7 10-14-2007 08:20 AM
Stupid stupid stupid Hi Lift question Ichytriggrfingr YJ Wrangler Technical Forum 11 04-23-2006 12:18 AM
Stupid Owner MikeS TJ Wrangler Technical Forum 4 05-22-2003 10:27 AM
