Stupid How do you replace the front headlamps?? - JeepForum.com
post #1 of 13 Old 08-25-2011, 11:05 AM Thread Starter
Fonz3482
Hello everyone,
I noticed lastnight that my rf headlamp was out. So I called for the parts, Im picking 2 new ones up on the way home. I have not even looked at it yet, but was wondering how to replace them. I assume you remove the 4 screws in the headlamp trim, remove the connector and it pops out??
Fonz3482 is offline
post #2 of 13 Old 08-25-2011, 11:32 AM
pasinbuy
Take the time to fill out your profile. We should not have to ask you about your Yj.
pasinbuy is offline
post #3 of 13 Old 08-25-2011, 11:43 AM
Leans93
She's my density...
Leans93's Avatar
Remove the four screws in the bezel and take those off. Remove the wiring plug on the back. Then on the front there are a few more screws to loosen that hold a metal plate that holds the headlight in place. Once this is removed swap the old for the new and install is reversed. There are also adjustment screws on the top and outside of each light. If your headlight aim is good I wouldn't touch those but if not use these to set the aim on your lights.
M.F. Leans
93' YJ 4.0L AX-15, 4" Pro Comp lift, 3/4" shackles, 1" BL, 33x12.5x15 BGF MT's, and some other stuff
Originally Posted by Mike Jones
Catch me on the highway or about to tear the mall up.
Leans93 is offline
post #4 of 13 Old 08-25-2011, 12:42 PM Thread Starter
Fonz3482
Sorry pasinbuy, I guess when I registered I got side tracked and missed that part. All filled out now!
Fonz3482 is offline
post #5 of 13 Old 08-25-2011, 07:58 PM
jay-h
look out, there are screws on the metal rim (inside) to remove the rim and headlamp, but there are also 2 screws for alignment. Don't mess with those or you'll need to re-align your lights.
jay-h is offline
post #6 of 13 Old 08-26-2011, 06:52 AM
tydp
yes, but
He only asked about headlights....I'm thinking all YJ's have the same square lights, so does it really matter what suspension, engine, etc he has...geez..
tydp is offline
post #7 of 13 Old 08-26-2011, 07:01 AM
Que89YJ
Typd, no it doesn't matter for the headlamps, but in the long run it will. It is difficult to know where to point someone in the right direction without it. Maybe not in this specific problem, but for most of them it does. Pasinbuy might have been a little more "discrete" (LOL) in asking for it but I understand it.
Que89YJ is offline
post #8 of 13 Old 08-26-2011, 10:19 AM Thread Starter
Fonz3482
Thanks guys, headlamps went in nicely. I replaced both fronts justto be safe. I'm putting it on the road in a few hours. Hope it runs and drives well with no more issues!!
Fonz3482 is offline
post #9 of 13 Old 08-26-2011, 10:26 AM
Redlightracer
Good job you will get better MPG now TOO !!!! LOL
Redlightracer is offline
post #10 of 13 Old 08-26-2011, 12:27 PM
hdfxrs91
1987 YJ Wrangler
You shouldn't tell stories like that. You know full well that adding pin stripes is the only way to get better MPG.
hdfxrs91 is offline
post #11 of 13 Old 08-26-2011, 01:56 PM
Leans93
She's my density...
Leans93's Avatar
NOT TRUE!! Type R stickers also add TONS of horsepower
M.F. Leans
Leans93 is offline
post #12 of 13 Old 08-26-2011, 11:11 PM
eaelliott5
I knew a guy once that used to burn Ferrari's just because he had a K&N sticker
eaelliott5 is offline
post #13 of 13 Old 08-27-2011, 12:16 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
This thread is full of win !
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is online now
How do you replace the stupid power steering pump?? MountainMan864 TJ Wrangler Technical Forum 25 11-24-2009 10:44 PM
Front Locker Question (Maybe a stupid one too) xkuzme1 TJ Wrangler Technical Forum 11 09-18-2009 08:47 AM
Stupid front axle question johnboy68 YJ Wrangler Technical Forum 2 08-08-2008 06:41 AM
Fixed my noise coming from front, Stupid Me! outerorbiter TJ Wrangler Technical Forum 6 11-19-2004 10:22 PM
Stupid Question (CJ Front-end) wingnut YJ Wrangler Technical Forum 2 01-07-2002 12:15 PM
