Stump Max Contest? - Page 2 - JeepForum.com
post #16 of 41 Old 04-27-2011, 07:08 PM
HurricaneRZA
Originally Posted by Vin91 View Post
Not going to lie those are chuck Norris jokes lol but i don't know
Mean max??
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
Originally Posted by YoureverydayXJ View Post
This is the most metal thing I have ever heard.
Originally Posted by doublins View Post
I always get people coming over and saying things like "I wish I knew how to do that," etc- but they don't realize- at some point I didn't know how to do it either- I had to figure it out.
HurricaneRZA is offline
post #17 of 41 Old 04-27-2011, 07:12 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I gotta say, this thread is pretty funny! Believe me, I'm stumped a lot more often than you may possibly think!
But thanks to MANY wonderful people in the Jeep community, especially here on JF, I have acquired more random Jeep knowledge than I ever thought I would. I only hope that passing along the things I've learned will somehow repay a portion of the debt of gratitude that I owe to so many.
And with that, I will now stump myself & ask for YOUR help!
I purchased a transfer case from Craigslist two days ago, sight unseen for $100 and a buddy picked it up for me. All the owner could tell me was that it was from a Cherokee (XJ or ZJ was not specified) and he didn't know what model it was. I bought it anyway.
As it turns out, it is an NP242 Part-time/Full-time transfer case. I am pretty familiar with these as I have swapped an NP249 for an NP242 in a ZJ I used to have, and our family WJ & our son's ZJ both have them too.
However, this one has something I've never seen. It seems to have 2 fluid lines running in/out above the front yoke. To where? For what? It's marked as a 242 AMC, but the build date is 3-15-96 which was long after AMC was dead & gone.
School me.
Max
Sent from my HTC Incredible Droid
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #18 of 41 Old 04-27-2011, 07:16 PM
Louie4
I don't know about a factory option for that Max but I do know of a mod for the NP231 that involves drilling and tapping the huge steel plugs and putting a hose fitting in each connected by a clear hose. It allows for easier fluid changes, plus you can see the color with the clear hose.
I'm sure that's not the answer but that's what I would use it for.
Maybe some kind of fitting for a cooler since it was a part-time/full-time case? It does a mini oil pump on the output shaft, correct?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #19 of 41 Old 04-27-2011, 07:22 PM
Tompatt
1987 YJ Wrangler
I have stumped Mean Max. and Max, that looks like someone did it themselves? Maybe to help the fluid flow through the transfer case?
Thomas
-1987 YJ
Tompatt is offline
post #20 of 41 Old 04-27-2011, 07:52 PM
Skydmark1
I don't know, it looks like the case was cast with two flat spots there meant just for the purpose of making a hole for those nipples.
-2013 JKU Sport, bone stock, Auto with 3.73's
-1998 ZJ Laredo, 4.0 42RE Selec-Track, 30" M/T tires
Skydmark1 is offline
post #21 of 41 Old 04-27-2011, 07:58 PM
Tompatt
1987 YJ Wrangler
That is how they are made, look at this picture from Novak
Thomas
-1987 YJ
Tompatt is offline
post #22 of 41 Old 04-27-2011, 08:12 PM
Skydmark1
Interesting, it is cast with those flat spots but without the nipples installed. Were they anticipating something?
post #23 of 41 Old 04-27-2011, 08:14 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I agree, I have seen the casting bosses on the cases before. I've just never seen them used.
I can't believe that the small slinger pump on the tailshaft would be able to supply the volume/pressure that a line of that size would require.
You can bet I'll be tearing into it to see what's going on.
Max
Mean Max is offline
post #24 of 41 Old 04-27-2011, 08:17 PM
Tompatt
1987 YJ Wrangler
guess we will never know. i searched for a pic of the inside of the 242. it doesn't look like you could tell where the bumps were on the outside. maybe to somehow strengthen the case?
Thomas
-1987 YJ
Tompatt is offline
post #25 of 41 Old 04-27-2011, 08:19 PM
Tompatt
1987 YJ Wrangler
Max
Keep us updated on what you find.. maybe make another write up
Thomas
-1987 YJ
Tompatt is offline
post #26 of 41 Old 04-27-2011, 08:23 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Will do! And as usual, pics will be included!
Max
Mean Max is offline
post #27 of 41 Old 04-27-2011, 08:30 PM
Mark05059
Max... I have figured out why you have never seen those lines before in a Jeep.
What you apparently have is a hummer 242 transfer case.
Inside you should see a cooling loop. (which is under recall) http://www.hummerknowledgebase.com/rungear/cooloop.html
now other then this I have no information on HOW it cools.... etc..
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #28 of 41 Old 04-27-2011, 08:42 PM
Tompatt
1987 YJ Wrangler
o damn. nice find.. heres another site.. http://flashoffroad.com/features/Tca...Jeep/tcase.htm
Thomas
-1987 YJ
Tompatt is offline
post #29 of 41 Old 04-27-2011, 08:44 PM
Mark05059
more info
Transmission fluid driven by transmission pressure of aproximately 90- 120 psi, goes through a cooler integrated with the engine oil cooler. From the cooler, the fluid goes though an intercooler loop inside the transfer case, and then back to the transmission. There is a bypass valve in circuit there to prevent the cooler fluid from all draining into the transmission pan.
http://www.hummerknowledgebase.com/r.../trancase.html
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #30 of 41 Old 04-27-2011, 08:45 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Ding, ding, ding!!!! Winna, winna, chicken dinna!
Blow up the pic of the tag that I posted. It says AMG, not AMC.
AM General, producer of the H1 Hummer.
What do I do with that?
It sure looks like a Jeep pattern. We shall see.
Max
Mean Max is offline
OFFICIAL: DECEMBER TJ of THE MONTH CONTEST!!! VOTE NOW!! THE CONTEST HAS STARTED!! EugeneTheTJ TJ Wrangler Technical Forum 136 12-14-2010 07:57 AM
NOVEMBER TJ of THE MONTH CONTEST!!! VOTE NOW!! THE CONTEST HAS STARTED!! EugeneTheTJ TJ Wrangler Technical Forum 127 11-30-2010 12:39 PM
AuGUST TJ of The Month contest... VOTE NOW!! THE CONTEST HAS STARTED! spyder6 Wrangler General Discussion 3 08-20-2009 12:50 AM
July TJ of the Month Contest, enter now contest has begun spyder6 TJ Wrangler Technical Forum 115 07-19-2009 10:04 PM
