Studs - JeepForum.com
post #1 of 3 Old 05-04-2011, 05:07 PM Thread Starter
weerwolv
Studs
Get your mind out of the gutter Ha-ha
Quick question to all...
Pulled my NP231 out of my 1993 YJ that had 150k miles and in process of replacing with another that had a lot less milage.
In removal, the hard to get stud didn't give up its nut and just backed itself out instead while all others stayed in the trasfer case.
Little bugger nut is fused to the old stud with rust.
Got a new stud and nut to replace.
Do you use red locktite when installing the stud into the transfer case so it won;t back out again?
Other question? Would you replace the AX15 Output shaft seal right now even though its not leaking while the TC is out?
Thanks all.
-Chris
weerwolv is offline
post #2 of 3 Old 05-04-2011, 05:41 PM
kloppk
Personally I'd use Blue locktite.
Be sure to put some antiseize on the fine pitch threads before putting the nut on.
I've done a number of tcase swaps and have never had the AX15 output seal leak.
Of course for piece of mind you may want to do it. A lot easier now.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #3 of 3 Old 05-04-2011, 05:44 PM Thread Starter
weerwolv
Thanks for the info. Blue for the stud and anti-seize on all nuts going back on.
Appreciate it.
Finally I am almost back on the road.
Now for lift kits and tires
weerwolv is offline
Water Pump Pulley - Studs vs no studs SpideYJeep YJ Wrangler Technical Forum 23 01-26-2016 07:47 AM
Lug studs bmire322 TJ Wrangler Technical Forum 5 09-12-2009 05:42 AM
Oil Pan studs George Dickel TJ Wrangler Technical Forum 7 08-22-2008 03:15 PM
bolts or studs? Carley1199 TJ Wrangler Technical Forum 0 12-14-2006 10:52 PM
any good studs around? PassaTDIesel TJ Wrangler Technical Forum 5 09-24-2006 11:34 AM
