Stuck steering wheel/gear selector - JeepForum.com
post #1 of 5 Old 07-15-2013, 09:02 PM Thread Starter
Budke
Got a friend with a YJ and she's having a problem with her steering column. This is what she told me : " Its all Locked up. i can't even take it out of park and then the ignition switch is messed up too"
Any idea's?
I can't think of anything really.
04 TJ- Short Bus. It's got some stuff.
Sometimes I question my sanity. Occasionally it replies.
Budke is offline
post #2 of 5 Old 07-16-2013, 09:23 AM
Randonexplosion
Randonexplosion's Avatar
Sounds like a woman trying to explain a problem
Maybe the trans has stress on it and doesnt want to shift out of park?
My girlfriend's tahoe did this. She parked on a slight incline in her Moms driveway and it locked up good. Hooked up to the truck in front of her and barely pulled to take the stress out and it shifted out just fine. Never did it again.
Is the ignition Switch messed up or the key cylinder?
Randonexplosion is offline
post #3 of 5 Old 07-16-2013, 11:25 AM Thread Starter
Budke
Not a clue. I asked her what it was doing and what happened before this happened. She doesn't know. But she said she got it to work. Asked her what she did but she hasn't said anything yet. I figured she just locked the steering wheel, but I don't remember if YJs do that or not. Never tried that in mine.
Budke is offline
post #4 of 5 Old 07-16-2013, 11:48 AM
Rproject
1987 YJ Wrangler
She likely locked up the steering wheel. Below the compression plate is a lock plate. It has slots around it that the column lock pin goes into to keep the wheel from turning without the key being in the run position. It's an anti-theft measure. If the pin binds on the plate, the key will bind as well. Very common situation. It can happen when someone gets their wheels bound up on a curb, or even when someone gets out of their car and their body rubs along the steering wheel, turning the wheel after the key is out. Happens to my wife all the time. The solution is to grab the wheel and try to rotate it one direction or the other. One direction will be a dead stop, the other will be stiff, but the wheel will move a few degrees. With the wheel pulled to the movable direction, and pressure is held in that direction, the bind will be removed and the key will be able to be turned.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #5 of 5 Old 07-16-2013, 12:16 PM Thread Starter
Budke
Thats what I told her to do. She said it didn't work when she tried it. She was probably just doing it wrong.
Budke is offline
