stuck on lockers - JeepForum.com
post #1 of 2 Old 12-02-2001, 10:57 AM Thread Starter
jeepnmud
stuck on lockers
alright so I've narrowed it down to either an oxlocker or an ARB air locker. Anyone out there have either of them, and what do you think of it? The ox locker had less parts to break, but will the ARB make me happier in the long run?
jeepnmud is offline
post #2 of 2 Old 12-02-2001, 01:04 PM
osburn
osburn's Avatar
The Ox Locker will be a good locker someday. But not yet. The reports are coming in now about them grenading. Mainly the two unrealistically small spider gears inside. Like anything new, it's gonna take time to get it worked out. The Ox owners are having quite the time getting them engaged also. It's much like trying to shift a twin stick type tcase into gear. You need a small amount of movement and a small amount of luck. But I do believe that these lockers will be top notch eventually. It just takes real world testing to work out the bugs.
I'm on my second set of ARBs now. You must have a reliable air source to run ARBs. If I were buying new lockers today, I'd only buy ARBs. I would never put up with the quirks of an auto-locker on the street, and the Ox just hasn't been around long enough for me to trust it yet.
Matt Osburn
Score 1032
osburn is offline
Rubicon Air Lockers vs ARB Lockers MLA 97TJ TJ Wrangler Technical Forum 17 07-09-2012 04:37 PM
Ever gotten stuck with lockers? zband TJ Wrangler Technical Forum 43 01-04-2009 08:58 PM
Stuck...Almostr Stuck...Looks Cool Vertical Norm TJ Wrangler Technical Forum 5 12-21-2006 10:56 PM
Lockers in front, lockers in back biffstephens TJ Wrangler Technical Forum 30 12-04-2004 02:45 PM
PICS almost got stuck, man i need lockers wakeboarder 21 TJ Wrangler Technical Forum 13 10-04-2004 07:05 PM
