stuck leaf spring bolt - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > stuck leaf spring bolt
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 02-23-2007, 10:32 PM   #1
TheBrainB
2011 JK Wrangler
Trying to get my lift installed. On both rear leaf spring to frame mount bolts, the bolts are stuck inside the bushings. Any ideas on removal???
Thanks
TheBrainB is offline   Reply With Quote Quick reply to this message
Unread 02-23-2007, 10:47 PM   #2
aviatorguy
Had to grind/cut mine out
aviatorguy is offline   Reply With Quote Quick reply to this message
Unread 02-23-2007, 10:58 PM   #3
TheBrainB
2011 JK Wrangler
Thats what I am afraid of.
Unread 02-23-2007, 11:04 PM   #4
aviatorguy
its not bad at all. just get a good angle grider and cut on the side of the perches. about 10 mins per bolt max
Unread 02-23-2007, 11:06 PM   #5
Burnerman
If you don't have new bolts already they're 9/16 x 4" long. bring a nut to the Hdwr store for the right thread pitch. Grade 8 or 5 at the least. I used a torch to cut mine off. You can use a sawzall but get good quality blades and it'll take while.
89' YJ Larado 4.0L,AX15
05' Grand Cherokee Limited, 2"OME lift and a Hemi.
Burnerman is offline   Reply With Quote Quick reply to this message
Unread 02-23-2007, 11:18 PM   #6
TheBrainB
2011 JK Wrangler
Thanks for all the info guys. If the BFH and torch don't work in the morning, I'll be cutting them.
Unread 02-23-2007, 11:56 PM   #7
Matt87YJ
1987 YJ Wrangler
I just put a lift on mine this weekend, after spending 3 hours trying to get them to come out I grabbed a grinder and they're off in a matter of minutes. Dont waste your time just cut them and buy new ones. Thats my 2 cents..
'87 Wrangler, Stroked with a few other toys...
Matt87YJ is offline   Reply With Quote Quick reply to this message
Unread 02-24-2007, 06:57 AM   #8
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
After, 2 hours fighting with BFH, sawzall, heat etc. I just ground mine off, took 3 mins per bolt.
I don't even bother unbolting them anymore, I just break out the grinder, it's much faster.
Richmond88yj is offline   Reply With Quote Quick reply to this message
Unread 02-24-2007, 04:34 PM   #9
Cross
I had the same problem yesterday, Cut the first bolt off then tried the air hammer on the second bolt. Should have tried the hammer first so I would not have had to buy a bolt.
Cross is offline   Reply With Quote Quick reply to this message
Unread 02-24-2007, 04:48 PM   #10
bamato
Cut them out! Those bushings bond to the metal in ways I never thought possible!!
/l , [____],
l---L--?lllllll?-
()_) ()_)----)_)
Mud is your Friend :)
Tread Lightly
Please help keep our trails clean for future generations to enjoy outdoor recreation as well!
bamato is offline   Reply With Quote Quick reply to this message
Unread 02-24-2007, 04:55 PM   #11
Cross
Oh, and use anti-seize on the new bolts so next time it is easier to get things out.
Unread 02-24-2007, 05:54 PM   #12
TheBrainB
2011 JK Wrangler
Cut-off wheels work wonders. Got both bolts out within 10 minutes. Got the lift installed and it looks great. Thanks for all the info.
Unread 02-24-2007, 09:27 PM   #13
Black91YJ
i heated the livin hell out of those bolts with a propane torch after some pb blaster and the torch on each bolt for about 10-15 mins then i just stuck and impact on em the bolts got so hot they melted the rubber around them to break em loose try that itll saye you grindicg cutting job
Black91YJ is offline   Reply With Quote Quick reply to this message
Unread 02-24-2007, 10:52 PM   #14
Cross
I Heated my bolts with an acetylene torch, they were red hot and still did not break loose.
Unread 02-25-2007, 06:51 AM   #15
drew2000
drew2000's Avatar
Impact gun to get the nuts off, BFH to drive the bolt out.
Drew
1994 YJ - 2.5L, 2" BDS w/1" Shackles
2006 Dodge Charger R/T (5.7L Hemi)
drew2000 is offline   Reply With Quote Quick reply to this message
