stuck in jeep mods - JeepForum.com
post #1 of 8 Old 06-18-2002, 12:56 AM Thread Starter
bigjeep39
bigjeep39's Avatar
stuck in jeep mods
Hmm, lets start this off with the fact i want to get a dana 44 rear end, will that work with a SYE kit when i get that, also.. where can i find a good SYE kit i was thinking of getting the RE kit and then i did some reading.. so it looks like i will go with the tera low?!?! where can i find it for sale, also i wanted to put my 4" springs SOA and will that be shotty or will it help, i also ordered the full traction k link steering and the 2" shackle reversal.. how will that affect me..it was designed to help jeeps with SOA get the tie rod and other steering items out of the way/eliminate bump steer at an affordable price, i was think of the M.O.R.E. kit or the Tri County Gear but i went with k link.. so that would put me at 4" + 5" + 2" that is way too much lift isnt it????
how big of tires will that fit, and if that seems weird should i get like 2" springs instead??
help me out please, thank you so much
shawn
1998 TJ
Slow steady project.
bigjeep39 is offline
post #2 of 8 Old 06-18-2002, 12:18 PM
TXaggieYJ
i mentioned this on another post, but here it is again....my buddy has a 95 with a 3" body lift, 1.5" shackles, 4" springs, and a spring over worth about 6". now that is high. he is currently running 35s, which he had before the SOA. to give some perspective, i am 6'5". when the door is open, the ledge to climb over to get in the seat is at my waist. i can reach up and rest my chin on the hood. as far as it being too high is your own opinion. it depends on what size tire you plan on running. with the removal of his side tube step bars he could probably fit 44s, but he will be upgrading soon to 38s. personally i will be using 4" springs for my upcoming SOA.
TXaggieYJ is offline
post #3 of 8 Old 06-18-2002, 12:50 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
For me .. a 4" suspension lift plus spring over fits 38" tires very well (military spec .. 325/85 r16) .. and that is without a bodylift. I feel like I am high enough already, but may cut out my wheelwells for the cool looking Bushwacker cutout / pocketed fender flares! That may make enough room for 40" tires.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #4 of 8 Old 06-18-2002, 01:45 PM Thread Starter
bigjeep39
bigjeep39's Avatar
Hmmm, well i wonder if my stock motor will handle this, i am going to be doing some mods to it, i will gear the rear probably to 4:56 or would 4:88 be better...oh and no one answered my questions on components like SYE and stuff??
shawn
1998 TJ
post #5 of 8 Old 06-18-2002, 07:38 PM
NaeKid
NaeKid's Avatar
Long story short .. depending on how large of a tire you goto, you might need to push a few more horses outta your engine-bay. Even changing gears in the axles to something in the 4.88 range might not help enough.
Once you start swapping engines, it is usually easier to use a fully swapped in drivetrain to start (engine to axles .. new drive-shafts), and once that starts to fail due to extreame usage, then start upgrading parts for that drive-train.
If you change out your T-case, most of the ones that you would want to use already have yoke ears attached (Atlas as an example). Your tagline states that you have the 285 I-6 .. but not which tranny. If its the 5-speed BA-10 (Peugot), then you will need to change it out sometime soon.
When my Jeep was "stock", I had the 258 I-6 engine, BA-10 tranny, 231 T-case and the D30 front and the D35 rear. On 33" tires, it didn't do too bad, other than I blew out 2 engines and 2 trannies in one year. That's the reason I went to a Chevy drive-train.
Hope this points you in the right direction.
Silver
NaeKid is offline
post #6 of 8 Old 06-19-2002, 01:22 AM Thread Starter
bigjeep39
bigjeep39's Avatar
Hey hey.. yah that really helps, it just seems all too much to swap over to a small block.. well i will check it out, i might bore mine 30 or 40 over like i originally planned..!!
shawn
1998 TJ
post #7 of 8 Old 06-24-2002, 06:16 PM Thread Starter
bigjeep39
bigjeep39's Avatar
Yah..So where do i find the SYE for sale??
shawn
1998 TJ
post #8 of 8 Old 06-25-2002, 05:30 PM Thread Starter
bigjeep39
bigjeep39's Avatar
Any help from anyone..it would be greatly appreciated??!!
1998 TJ
mult mods now stuck on 4H..Need help! erekv2 YJ Wrangler Technical Forum 26 08-25-2009 05:48 PM
Turner: A collection of Jeep, Jeep Mods, and Wheeling. Turner YJ Wrangler Technical Forum 39 05-17-2009 09:38 PM
Jeep Mods rugbygode2 Wrangler General Discussion 8 08-06-2008 02:44 PM
first ever jeep mods onemoretry TJ Wrangler Technical Forum 12 01-16-2006 08:54 PM
My new jeep mods frhalevt TJ Wrangler Technical Forum 1 01-11-2004 02:18 PM
