stuck in four high - JeepForum.com
post #1 of 10 Old 03-03-2008, 05:17 PM Thread Starter
coolgreen
coolgreen's Avatar
stuck in four high
My Jeep seems to be stuck in four wheel drive. When I shift into 2 wheel, the front axle appears to disengage, but the 4wd light stays on and the front driveshaft is still engaged.
I had a problem with my vacuum lines going to the front axle a few months ago, but I found the leak and fixed it. My problem at that point was no four wheel drive.
I'm going to check the linkage, but it feels OK.
Any ideas?
1995 Yj 6cyl. Auto all stock landscaping work truck w/add-a-leaf kit - very harsh ride - running a 6.8-foot SnoWay plow.
coolgreen is offline
post #2 of 10 Old 03-03-2008, 06:07 PM
xboardr311
one thing i could think of is to check the fluid in the transfercase. if its low and depending how low it wont disengauge
xboardr311 is offline
post #3 of 10 Old 03-03-2008, 07:13 PM Thread Starter
coolgreen
coolgreen's Avatar
Thanks, I will check it tommorrow.
post #4 of 10 Old 03-05-2008, 11:21 AM
ksjohn
I am having the same issue on my '89. I changed the transfer case fluid and it still feels like it is in 4 wheel drive but the front tires don't spin, the front drive shaft is turning. When I do pull it inot 4 high the front tires spin like it should. The linkage feels goods.
A buddy of mine 99 TJ and his drive shaft is turning while he is in 2wd.
Thanks in advance for any suggestion.
ksjohn is offline
post #5 of 10 Old 03-05-2008, 01:05 PM
Yeepin
1995 XJ Cherokee
I had almost the same problem.. problem with mine was i would shift it into 4wd the front driveshaft would spin but the tires wouldnt.. So i just tore apart the shift fork on the axle and it was stuck so i just hit it with a hammer and manually shifted it into 4wd. Every scince it worked fine. Check your axles shift fork out see if its stuck inbetween 2wd and 4. Because the 4wd light is just a completed circuit right off the shift fork.
1995 YJ Check it out.....
1995 XJ For sale check out my classifieds (lifted 35's ect)
1999 Dodge Dakota
Yeepin is offline
post #6 of 10 Old 03-05-2008, 01:06 PM
Yeepin
1995 XJ Cherokee
Also make sure all the vaccume lines are hooked up... If so take the vaccume line of that conects to the front axle and shift your jeep in and out of 4wd. Then hook the line back up and see what happens...
1999 Dodge Dakota
Yeepin is offline
post #7 of 10 Old 03-05-2008, 02:16 PM
bhartwell59
1987 YJ Wrangler
i was once told that if you ever were stuck in 4wd and wanted 2hi to drive in reverse and do a figure 8. i can't speak from experience on this tho.
4.2 '87 yj, 300,000+ miles, mopar mpi, 33" bfg mud KM2, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 sye conversion, tom wood's hd driveshaft, magnaflow cat/custom exhaust, 4wd rear bumper/swing-out tire carrier
bhartwell59 is offline
post #8 of 10 Old 03-17-2008, 02:22 PM
ksjohn
This past weekend I took my 4wd acutator off and found that it was stick in the locked position. I just pulled it back by hand and slid the collar over to match the shift fork and the problem was solved. While doing this I broke off a vacumm port on the acutator(rusty). I called local parts dealers to see how much the actuator is and they said about $140. I will fix that by installing the manual system discussed in the other pages. I hope this helps.
Thanks
ksjohn is offline
post #9 of 10 Old 03-20-2008, 07:15 AM Thread Starter
coolgreen
coolgreen's Avatar
I found the problem
Thanks for the advice, guys. It turned out to be another vacuum leak. I got the Jeep out of 4wd by fixing one side of the vacuum harness (for the second time), but then it wouldn't go into 4wd. It turned out that the other line broke while I was fixing the other side. After fixing that side, I now have 4wd and 2wd again.
I think it's definately time for a new vacuum harness, or even better, one of those cable-operated posi-lok gizmos.
post #10 of 10 Old 03-20-2008, 08:10 AM
jaw41272
jaw41272's Avatar
if you can just replace vacuum hoses , I would go that route for now, posi lok is nice, but its much easier to use the factory set up, if the posi lok isnt adjusted properly it doesnt work properly, can be a pita
91 Sahara 4.0l Operation Welcome Home Parade Veh #69
PARADE JEEP MEMBER #1Auto posi-lok equipped, 4" susp. lift
K&N Drop in and loaded with battle scars
FOR SALE 2005 PT CRUISER CONVERTIBLE
2005 Suzuki DRZ400S For SALE
jaw41272 is offline
fan switch stuck on high and will not shut off smitkev2 YJ Wrangler Technical Forum 1 06-29-2009 03:55 PM
High Beams Stuck On! zephyrmays TJ Wrangler Technical Forum 17 05-17-2009 06:41 PM
Steering Wheel Stuck / High Beams Broke mazyj YJ Wrangler Technical Forum 2 11-16-2008 07:52 PM
help-4 wheel drive high is stuck mysweetfracture TJ Wrangler Technical Forum 28 02-18-2003 04:27 PM
89YJ Stuck in 4-High newtonca YJ Wrangler Technical Forum 9 11-04-2001 03:23 PM
