stuck in 4wd - JeepForum.com
post #1 of 3 Old 02-01-2013, 06:29 AM Thread Starter
boxcar119
stuck in 4wd
Searched but no help maybe some one can make a suggestion
Used the 4wd in the snow a week ago now my front drive line
spins all the time no matter where the t-case lever is except neutral.
not sure if the axel is engaged but i get no 4wd light and feel no
vacum from either vacum line at the axel.
any suggestions?
Thanks
boxcar119 is offline
post #2 of 3 Old 02-01-2013, 08:02 AM
EABiker
Well, consider yourself lucky, most posts are about the opposite problem!
Pull the cover of the front axle disconnect; it sounds as if the shift fork is somehow stuck, locking the collar to the shaft.
EABiker is online now
post #3 of 3 Old 02-02-2013, 12:42 PM
seattle_yj
X2 it's that damn actuator. You can lock it over, balance the front shaft and call it a day. Or replace the unit with a posi lock switch. I have the switch and I like it but I drive a lot on the freeway.
seattle_yj is offline
