was stuck in 4 low drove it for on the highway 60 miles! - Page 2 - JeepForum.com
post #16 of 27 Old 04-08-2010, 09:34 PM
tc90xj
1994 XJ Cherokee
There is no way you went 60 mph in 4 lo and only turned 3000k rpm. it was 4High if anything.
tc90xj is offline
post #17 of 27 Old 04-08-2010, 09:37 PM
stu1021
Even in 4HI it would be tough on the tcase on pavement for that distance. You must have felt it going around turns since the stock tcase set up doesn't slip.
'90 YJ Wrangler - 4.3L Chevy
'91 GMC 3500 Bus - Tow Vehicle
'87 MBenz 300D Turbo
'02 MBenz E55 AMG
'55 Piper Apache
stu1021 is offline
post #18 of 27 Old 04-08-2010, 09:44 PM
Apollo12227
No way on earth you were in 4lo doing 60... your RPM's would have been through the roof, whether your tach was working or not that engine would have been absolutly screaming to get you to that speed. When I hit the sand dunes around where I live I beat the living hell out of my transfercase by leaving it in 4lo flying through gears with my TF999 automatic... 3rd gear hiting 35 was quite a task and my engine wasn't quiet about the situation either.
Good news is my transfercase survived the day, bad news is, I still love to put what's left of my stock equipment to the test! Still running 36" tires, 3.07 gears, and 8+ inches of lift with my dana 35... But dont tell anyone around here that there is dana 35 has lasted 2+ years with no signs of failing, one fluid change, sand in the tubes, and pushing 36's. ... According to overwhelmingly bad repuation of the turdy5 it should have blown up the moment I put the jeep in drive after installing the lift and tires haha.
Apollo12227 is offline
post #19 of 27 Old 04-08-2010, 09:49 PM
Burnerman
Burnerman's Avatar
The only reason it's alive is because of the automatic.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #20 of 27 Old 04-08-2010, 09:50 PM Thread Starter
fitbmxseries1
1987 YJ Wrangler
yeah there is no way iwas in 4 low but 4 wheel was engaged had to have been hi. finsihed some stuff up on it and took it for another spin tranny is slipping like crazy so im heading to a yard tommorow and grabbing another tf999 for 300$. should be a quick swap maybe i should just pull the engine too and get it cleaned up and painted. that means another week or so before i can drive it now! who would have thought a jeep for under 3000$ has problems....
fitbmxseries1 is offline
post #21 of 27 Old 04-08-2010, 09:52 PM
Apollo12227
May be a silly suggestion but the TF999 is a pretty strong tranny, make sure you've got fluid in it lol. My TF999 slips like its been blown appart when the fluid gets even a little low.
Please explain! I'm dying to hear a reason why that thing is still purring after what i've put it through lol. How does an automatic spare the spider gears the ravaging that most 35's take? I'm not being sarcastic at all, your the first person that's provided insight as to why I cant get this thing to blow up!
post #22 of 27 Old 04-08-2010, 09:52 PM
Mark05059
grab the transfer case while your there for a spare
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #23 of 27 Old 04-08-2010, 09:52 PM Thread Starter
fitbmxseries1
1987 YJ Wrangler
its got 2 bad ujoints up front so even when i put it in 2 wheel drive i couldnt tell the differnce when i turned. Ive replaced them eairlier today and its smooth and quiet now.
post #24 of 27 Old 04-08-2010, 09:58 PM Thread Starter
fitbmxseries1
1987 YJ Wrangler
way ahead of you got one sitting in the shop! not sure if its the right one though....
the trannys got fluid... but when ever i move the shifter out of drive then back into drive it will work again untill i drive it for a few mins then it happens again. Tranny was just flushed like a week before i bought it, im guessing the previous owner was having issues too then. But you got me thinking i should drop the pan and see if theres any visual issues.
post #25 of 27 Old 04-08-2010, 10:06 PM
Apollo12227
with an automatic you wont be able to see too much visually unfortunatly. Its worn fluid channels and clutch material that your dealing with, nothing thats too easy to spot without taking the tranny apart first. The only thing you can hope to "see" is whether the fluid is burnt up (black and smells like death)... Or if the bands need adjusting. There are big bolt looking things on the bottom of the tranny you can see after pulling the pan and you turn them to adjust your bands... A chilton or haynes manual will tell you step by step how to adjust them.
But 300 bucks is a pretty sweet deal for an automatic that is in working order, if you've got the money, 300.00 isn't a bad insurance price.
post #26 of 27 Old 04-08-2010, 11:00 PM
bigorangeyj
ive done 43mph in 4 lo. 33's 3.07's, and turning 4500 in fifth. it was on a dirt road between mudholes.
bigorangeyj is offline
post #27 of 27 Old 04-09-2010, 06:08 AM Thread Starter
fitbmxseries1
1987 YJ Wrangler
i just want too see if theres any black or burned fluid built up in the pan. being that it was changed recently just looking at the stick it looks clean. and theres actually a few tf999 at some local yards for around 200-300. working condition Car-Part.com--Used Auto Parts Market lets you search local yards.
Girlfriend drove TJ in 4WD today on dry pavement. 8 miles to work. {BANGHEAD} WheelinTJ2004 TJ Wrangler Technical Forum 32 01-30-2009 09:45 AM
I drove 1200 miles to get my OD back MichaelW JK Wrangler Technical Forum 6 08-30-2007 11:15 AM
drove one now i want it ToMchFn TJ Wrangler Technical Forum 16 06-15-2006 01:49 PM
Just drove my first TJ venom4x4 TJ Wrangler Technical Forum 20 03-11-2006 05:29 AM
