was stuck in 4 low drove it for on the highway 60 miles! - JeepForum.com
post #1 of 27 Old 04-08-2010, 02:31 PM Thread Starter
fitbmxseries1
1987 YJ Wrangler
Well i just bought this yj and i tested the 4low while test driving it and it shifted ed in but then the linkage musta broke cause it stayed in 4 low on the 60 mile ride home. right now i have the springs off of it doing some rust repair (thats when i knowticed it was broken and stuck in 4 low) so i cant drive it but does any one expect i damaged my transfer case?
fitbmxseries1 is offline
post #2 of 27 Old 04-08-2010, 02:34 PM
Louie4
As long as you're good on fluid levels and didn't go over 45-50 mph in 5th gear you should be fine. You could have manually shifted the t-case from underneath. I've had to do that.
Once you get it back together and in 2wd see if it makes any funny noises while going down the road.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 27 Old 04-08-2010, 02:39 PM Thread Starter
fitbmxseries1
1987 YJ Wrangler
i was at a constant 60mph the whole ride home with a plow on front. I thought it was stuck in 4wheel but i just figured it was driving differnt due to the plow... i fixed the linkage good as new but just hoping nothing got wrecked. Ill probably be able to take it for a spin tommorow night and see.
post #4 of 27 Old 04-08-2010, 02:53 PM
jaywiz1977
I didn't know 60mph in 4lo was possible???Your motor must have been SCREAMIN at ya the whole time!Throw it in 2wd and see it makes nasty noises,if not you should change the TC fluid and tell it your sorry.
There are alot of different people in the world out of all of them,it's the normal ones that scare me the most!
jaywiz1977 is offline
post #5 of 27 Old 04-08-2010, 02:57 PM
Louie4
I can't recall if I could hit 60 in 5th gear in 4LO. If I did I was pushing 5K+ rpm's.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #6 of 27 Old 04-08-2010, 03:14 PM
provinT13
If you were in 4-lo at 60mph you're engine is probably about to fall apart as well as your t-case. Are you sure it was on 4-lo and not 4-hi?
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #7 of 27 Old 04-08-2010, 03:21 PM Thread Starter
fitbmxseries1
1987 YJ Wrangler
yeah im 100% it was in 4 low. Its got a 318 swapped in instead of the 4.0 though. it was riding at 60 didnt seem like the engine was screaming but was revving a bit high not enough to do damage to the engine. dont know what gearing it has though.
post #8 of 27 Old 04-08-2010, 03:23 PM
provinT13
Yea that was probably hell on your t-case
post #9 of 27 Old 04-08-2010, 03:41 PM Thread Starter
fitbmxseries1
1987 YJ Wrangler
rebolted the shackles back in and took a spin around the block. no noise coming from the t-case. but i can imagine what happend inside of there! lots of heat and lots of shavings. i should probably pull it and check it out.
post #10 of 27 Old 04-08-2010, 03:47 PM Thread Starter
fitbmxseries1
1987 YJ Wrangler
i need to figure out what transmission this thing has. not sure if its the stock TF999 or if it was swapped with the 318.
post #11 of 27 Old 04-08-2010, 04:31 PM
djsmith1174
At 60 mph with a 2.41 or 2.72 TC lo range would have put it likely in the 5000+ rpm range! Of course other limiting factors would axle ratio, overdrive, and tire size. Does it have a tach in it? My 2.5L, ax-5, np-231, 4.10 gears, and 31 in. tires turns around 2600 rpm at 60 mph in hi. So in lo it would be around 7100 rpms. Yikes! Hope nothing is damaged. Enjoy your new Jeep.
djsmith1174 is offline
post #12 of 27 Old 04-08-2010, 05:00 PM Thread Starter
fitbmxseries1
1987 YJ Wrangler
rpms guage didnt fully work but never went over 3 grand at 60. now im not 100% sure it was in 4 low! were the shifter lined up to the linkage would indicate that it broke in 4 low and thats were the linkage sat. but it really didnt rev very high..... so by going on what your saying it must not have been in 4 low.... it did start to run a bit too hot but i did have a plow on it when it was 70 degrees out.
4 low should have the linkage pushed all the way forward right? the shifter will be pulled all the way back pushing the linkage forward if im not mistaken. im hoping it was just in 4high then!
post #13 of 27 Old 04-08-2010, 06:02 PM
bharris68
Daily Driver
Chances are good the lever broke before it went into 4Low - Based on what you're saying, my vote is there is absolutely NO way that Jeep was in 4 low for that long at drive at that speed. Even in 5th. gear you're lucky to get to 35 or 40 miles an hour without hearing a deafening roar under the hood and under your feet from the transfer case and engine.
Once the shifter is fixed, I think that you're good
bharris68 is offline
post #14 of 27 Old 04-08-2010, 06:46 PM
sailmike83
If you know the tranmission/tranfercase/axle gear ratios you could get an idea of what RPM you would likely be pulling at 4Lo.com :: Final Gear Ratio, Crawl Ratio, Tire Size Calculators
Roads...? Where we're going.. we don't need roads.
sailmike83 is offline
post #15 of 27 Old 04-08-2010, 08:29 PM
VermonterLost
I gotta go with everyone else here, I don't see how it's physically possible to do 60 in 4lo. I don't even think you can do 35 in 5th, redlining the hell out of the thing with it in 4lo. Are you completely sure it wasn't in 4HI?
VermonterLost is offline
Girlfriend drove TJ in 4WD today on dry pavement. 8 miles to work. {BANGHEAD} WheelinTJ2004 TJ Wrangler Technical Forum 32 01-30-2009 08:45 AM
I drove 1200 miles to get my OD back MichaelW JK Wrangler Technical Forum 6 08-30-2007 10:15 AM
drove one now i want it ToMchFn TJ Wrangler Technical Forum 16 06-15-2006 12:49 PM
Just drove my first TJ venom4x4 TJ Wrangler Technical Forum 20 03-11-2006 04:29 AM
