#1 | |
Strecthing wheel base.
Just a quick question about strecthing my wheel base.
I noticed a lot of guys are moving the hangers to accomodate the length of the springs, but I was wondering if I could use my stock locations for some sort of springs? XJ preferably. Also, did you guys go with stock springs or did you guys order springs for lifts? As you can tell, I'm bored and want to cut something.
Zane Neher 88 YJ. H.O. 4.0L/AW4/twin sticked d300/1 tons/38.5s. |
#2 |
BUILT. NOT BOUGHT.
the only way you could get more wheelbase using yj springs would be using offset spring perches like those offered by M.O.R.E.
the only way to use xj springs to achieve a stretch is to relocate your spring perches, in the rear, and with the little bit of space you have to work with the shackle hangers on the rear crossmember/bumper work best from what i've seen. ruffstuffspecialties makes a "way-back shackle hanger" that sells for about $35 a set. just make sure before welding them up your mounting surface is plenty strong. i replaced that sheetmetal crossmember that the bumper mounts to with 2x4" 1/4" wall steel and then butted another piece up against it to move everything back a bit more and serve as a bumper....
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS! |
#3 |
Appreciate it, man.
#4 |
You can cut the spring mounts off the frame and put YJ springs where ever you please.
#5 |
Waggy springs a offcenter and will give you a two inch streach I think and I believe will bolt up to a yj
We are VT |
#6 | |
#7 |
Remember you'll need to move shock mounts, if you go too far there are gas tank clearance issues also, and of course the are drive shaft lenghtening.
Sounds like a plan. I did mine, and absolutly love it. Doug |
#8 |
I used the waggy springs and gained 2" in the front and 2" in the rear and I dont have an issue with the stock fuel tank. stock waggy's are about 1.5" lift over stock YJ springs.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
