Strange Things..... - JeepForum.com
post #1 of 12 Old 05-17-2010, 07:49 AM Thread Starter
bl907
Strange Things.....
Have an 88 YJ with the 6 cyl, manual transmission. Recently I put on a 4" rough country lift and 1 inch shackle lift. I now have a strange sound. It is a cross between grinding and rushing water noise. Starts in idle and continues in all gears forward. Sometimes when I hit a bump it will go away briefly and in reverse it is not existent. The sound gets louder with the rpms. I was thinking my throwout bearing, but even with my clutch engaged the sound is still there. Any ideas???? Thanks.
bl907 is offline
post #2 of 12 Old 05-17-2010, 08:34 AM
muddy93
1987 FSJ Wagoneer
Dose the sound go away when you come to a stop, or is the sound present when ever the engine is running?
Did you install a T-case drop, or SYE along with the lift?
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #3 of 12 Old 05-17-2010, 08:34 AM
CrawlingForward
Does the noise change at all when pressing the clutch pedal in and out?
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #4 of 12 Old 05-17-2010, 08:54 AM
Roadyy
Check all your clearances under the tranny all the way back it sounds like something is rubbing...
Are you running antiwrap?? you said it doesnt do it in reverse. could be the rearend twisting allowing something to rub in forward.
X2 on SYE or t-case drop??
Roadyy is offline
post #5 of 12 Old 05-17-2010, 10:20 AM
clush
x3 on the transfer case drop/SYE. I just finished putting a 4" RC lift on too, but haven't had time to do the drop and no money for SYE yet. Haven't driven it, figured I would leave it in the garage till I could break the dang skid bolts loose somehow and get the drop done. PB Plasterin' the heck out of them right now!
clush is offline
post #6 of 12 Old 05-17-2010, 03:38 PM Thread Starter
bl907
I did the transfer drop kit. The sounds is there even at an idle. It gets louder with the RPM's. Again, in reverse there is no "strange" sound. The sound does not change when I turn left and right. Thanks in advance to your help and replies.
bl907 is offline
post #7 of 12 Old 05-17-2010, 04:06 PM
MJMPC
See if your fan is hitting the shroud.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #8 of 12 Old 05-17-2010, 04:20 PM Thread Starter
bl907
I definately did not think about my fan, but when I get off of work I will check it. Thanks
bl907 is offline
post #9 of 12 Old 05-17-2010, 09:14 PM Thread Starter
bl907
Discovered my "strange" sound tonight. Come to find out it was that my head cover was resting on my firewall. So all the sound of the engine was coming straight into my jeep. Took a board and a big ol' hammer and customized my firewall to accomodate the new angle of the motor after my transfer case drop.
bl907 is offline
post #10 of 12 Old 05-17-2010, 09:17 PM
patrick18
Good catch. Didn't even think of that one.
patrick18 is offline
post #11 of 12 Old 05-17-2010, 09:20 PM
MOjeeps
Thats a good thing to check, most people might over look the small things. Im real glad it worked out for ya!
MOjeeps is offline
post #12 of 12 Old 05-17-2010, 09:30 PM
Missouribound
Don't you mean you used a BFH?
Missouribound is offline
How much can I ask for these things? jeeperscreep04 Wrangler General Discussion 2 09-02-2009 10:28 PM
New to Jeeps few strange things i see slaughter1600 TJ Wrangler Technical Forum 2 04-17-2009 09:34 PM
Strange things happening Bigboyky YJ Wrangler Technical Forum 3 10-06-2008 11:38 AM
Two things Bhelliom TJ Wrangler Technical Forum 3 07-27-2006 05:03 PM
got some things done but need help New2theYJ YJ Wrangler Technical Forum 4 05-14-2006 11:28 PM
