Strange Starting Problem - JeepForum.com
post #1 of 12 Old 10-10-2006, 12:02 PM Thread Starter
atomicmoose
Just call me Moose
atomicmoose's Avatar
Last night when I went to start my Jeep, it seemed as if the starter was having trouble turning the engine over... like something was fighting it. It's hard to explain, but it almost mimicks a low battery condition. But then, it will get passed it and fire up. It has done this a handful of times since I installed the MC2150. Starter and battery along with battery cables are all new within the last year. Any ideas?
atomicmoose is offline
post #2 of 12 Old 10-10-2006, 04:55 PM
JaySpencer66
Condensation or a partial ground fault? I coated the bolts of my cables running on the starter with liquid electrical tape, but I had no issues to begin with.
/l , [____],
l---L--[]lllllll[]-
()_) ()_)----)_)
Member #1 of the "I Hate Torx Club!"
~anyone with a Jeep is an automatic member, and anyone can be member #1~
JaySpencer66 is offline
post #3 of 12 Old 10-10-2006, 08:35 PM Thread Starter
atomicmoose
Just call me Moose
Condesation on the leads?
post #4 of 12 Old 10-11-2006, 03:47 AM
Comanche5L
your contacts are gettting stuck in the started sylanoid(sp?). next time it does it, take a hammer or a pipe and tap the littlething attached to the starter. i bet ya it will turn right over.
'88 Comanche, '01 front clip, Mustang 5L, T-5 & Tonns of unnecessary noise
'91 Comanche, '01 front clip, I6 H.O, RE 3.5" Superflex
'91 CJ'd Sahara 4L
Comanche5L is offline
post #5 of 12 Old 10-11-2006, 07:39 AM Thread Starter
atomicmoose
Just call me Moose
I am beginning to think this is a problem with the altenator. This morning was another hard start, but it did turn over...eventually. While driving in to work this morning, I noticed that the blinkers were blinking slowly. The voltage gauge on the dash is reading about 8 volts. Obviously, that is low. Is there any way for me to test the alt, or can I get it tested somewhere? (other than my mechanic )
post #6 of 12 Old 10-11-2006, 02:34 PM
Comanche5L
to test the alt, start the jeep, turn the headlights on, and pull the +pos cable off the battery. if the alt is good, the jeep will stay running, if not is will stall out.
'91 CJ'd Sahara 4L
post #7 of 12 Old 10-11-2006, 05:53 PM
forum32
forum32's Avatar
I actually have the same problem, my alternator and starter are new and my timing is good. I never did figure it out.
1988 6Cyl YJ - Just keep it running.
forum32 is offline
post #8 of 12 Old 10-12-2006, 09:09 AM Thread Starter
atomicmoose
Just call me Moose
battery was totally dead this morning...with jumper cables attached, the volt gauge read 12volts....started the jeep fine, and disconnected the cable from my Rover, volts dropped back down below 8.
post #9 of 12 Old 10-12-2006, 09:44 AM
wolf3902
you can go to Advance or autozone and get the alt checked for free.
'93 YJ 2.5 Jasper; 5 speed
All stock, waiting to be reborn.
6/19/05 ...2" BDS suspension lift...the rebirth has begun!!!
ONE NATION, UNDER G O D
Support It, or Leave It!
wolf3902 is offline
post #10 of 12 Old 10-12-2006, 09:47 AM Thread Starter
atomicmoose
Just call me Moose
When I get a chance, that is first on my list.
post #11 of 12 Old 10-12-2006, 10:03 AM
wolf3902
Make sure the belt is tight also. But as long as it is, I'd guess it is the alternator.
Now, you can replace it if it's bad, or you can, if you have basic tools and ability, rebuild it with new brushes and a voltage regulator.
wolf3902 is offline
post #12 of 12 Old 10-12-2006, 11:40 AM Thread Starter
atomicmoose
Just call me Moose
Never rebuilt one before... how hard is it?
Strange Starting Problem Douglas S. YJ Wrangler Technical Forum 1 03-21-2009 03:39 PM
strange starting problem NJscott YJ Wrangler Technical Forum 8 05-08-2008 09:38 AM
Strange starting problem karbu TJ Wrangler Technical Forum 7 07-15-2006 07:42 PM
Strange starting problem... atomicmoose YJ Wrangler Technical Forum 23 01-22-2006 01:14 AM
4.2 liter Strange Starting Problem MendoXJ YJ Wrangler Technical Forum 1 10-13-2005 09:19 PM
