Strange Starting Problem - JeepForum.com
post #1 of 5 Old 01-24-2012, 08:21 AM Thread Starter
Joe203
A few times recently when the Jeep sits for a day or two, it will almost start and then dies. More cranking does nothing. I then pour a little gas down the carb and it starts and most of the time will run fine after that. I thought it was water and gas line freezing but it has done it when it's above freezing too. The fuel pump and filter are less than a year old. My thoughts are that the floats are getting stuck closed or the carb has an internal jet problem. The fuel filter is the type with two exits and the fuel may be going back to the tank instead of to the jets. What do you think? I've checked other threads with this title and they are not similar problems.
Joe203 is offline
post #2 of 5 Old 01-24-2012, 10:01 AM
Que89YJ
It sounds like a carb issue for sure. Have you thought about a rebuild on the carb?
Que89YJ is offline
post #3 of 5 Old 01-24-2012, 03:05 PM Thread Starter
Joe203
Actually I'm thinking abot the Motorcraft carb conversion the guy on Ebay sells. With a new auto choke it's about $300.00
Joe203 is offline
post #4 of 5 Old 01-24-2012, 03:38 PM
CARDOKTR
1987 YJ Wrangler
Sounds like u have an accelerator pump problem in the carb
CARDOKTR is offline
post #5 of 5 Old 01-24-2012, 03:47 PM
OKwranglerYJ
Or your jets aren't seating and it's emptying your bowl. It wouldn't be the accelerator pump because it only does it after a few days. I am not familiar with jeep carbs but I have rebuilt a bunch of others and nothing is as hard to rebuild a a quadrajet so a simple rebuild kit should get you going.
OKwranglerYJ is offline
Strange Starting Problem Douglas S. YJ Wrangler Technical Forum 1 03-21-2009 03:39 PM
strange starting problem NJscott YJ Wrangler Technical Forum 8 05-08-2008 09:38 AM
Strange Starting Problem atomicmoose YJ Wrangler Technical Forum 11 10-12-2006 11:40 AM
Strange starting problem karbu TJ Wrangler Technical Forum 7 07-15-2006 07:42 PM
Strange starting problem... atomicmoose YJ Wrangler Technical Forum 23 01-22-2006 01:14 AM
