Strange Starter behavior - JeepForum.com
post #1 of 3 Old 05-29-2012, 12:00 PM Thread Starter
jkazor
I have a 1995 4 cyl Wrangler that began to make exactly three brief successive grinding noises after it is started.
It is the same sound that one would hear if they tried to engage the starter after the engine was running, and the timing of these three grinds is the same each time I start the vehicle.
It appears to be an electronic issue where the vehicle doesn't know it is already running and tries to start itself, but as far as I know, a 1995 Wrangler never had that feature. And the vehicle is completely stock, with no electrical mods or upgrades.
To give you some additional background, I believe this behavior may be related to a repair I made immediately prior to the time it began. I lowered the windshield, removed the dash bolts and pulled it away from the cowl just far enough to replace the left front speaker. Although, I was pretty careful, I am sure this new problem is related to something I may have disturbed during the repair process.
I have since noticed that these three consecutive starter grinds coincide with three warning beeps. It appears that the PCM is is giving some sort of warning related to starting.
I have gone through the wiring in the general area but have yet to find the cause. Any ideas?
jkazor is offline
post #2 of 3 Old 05-29-2012, 07:17 PM
87wheeler
1987 YJ Wrangler
your starter connections could be loose causing it to make that grinding noise. Also how old is the starter? it could be that you may need a new one
87wheeler is offline
post #3 of 3 Old 05-30-2012, 10:01 AM
Que89YJ
Warning beeps from the ECU? Do a video of it and post it up. The ECU or cluster doesnt have any chime. I need to see and hear to help.
Que89YJ is online now
grinding noise , starter
Poor Starting and Strange Fuel guage behavior Zachnap TJ Wrangler Technical Forum 15 10-28-2010 02:07 PM
Strange Front Marker Light Behavior FooK TJ Wrangler Technical Forum 6 11-11-2009 02:15 PM
Odd Starter Problem, Strange Fix EB23 YJ Wrangler Technical Forum 0 05-20-2008 03:52 PM
Strange Behavior wonderwouldyou TJ Wrangler Technical Forum 1 10-08-2006 11:46 AM
Strange TJ Behavior booyia TJ Wrangler Technical Forum 5 03-20-2006 10:02 PM
