Strange New Starting Issue - JeepForum.com
post #1 of 4 Old 10-23-2011, 05:34 PM Thread Starter
ApocalypseJeep
So, recently over the last couple of weeks when I go out to start up the rig in the morning it stalls out on the first start up. What I mean is when I crank the motor, it starts fine, then drops in revs and sputters out untill it dies. When I restart it it runs fine. Then for the rest of the day, any time I restart it, no problems at all. So for the last week when starting it, I give it a light rev to keep it from stalling and it's fine. All vaccum lines are new, and I'm not getting any trouble codes.
Has any experienced these symptoms before, to find out what the problem was later? It runs and drives fine, just that little issue in the morning. Any ideas? My guess it's a fuel issue, but I could be wrong.
ApocalypseJeep is offline
post #2 of 4 Old 10-24-2011, 07:33 PM Thread Starter
ApocalypseJeep
Really, no one has ever heard of these problems? Wow, hard to believe.
BUMP!!!!!!
post #3 of 4 Old 10-24-2011, 08:44 PM
kloppk
Could be a fuel delivery issue.
Check the fuel pressure at the fuel rail to see if it's within spec.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #4 of 4 Old 10-24-2011, 09:39 PM
dodger889
Check the connectors at Cam Position Sensor and Crank Position Sensor. Pull them part and check for corrosion. Then the other has been mention above.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
Strange Starting Sound matty-g TJ Wrangler Technical Forum 2 12-15-2010 11:43 PM
Strange Starting Problem Douglas S. YJ Wrangler Technical Forum 1 03-21-2009 03:39 PM
Strange noises when starting up. Rio-Bravo TJ Wrangler Technical Forum 2 11-21-2007 09:37 PM
Strange starting problem karbu TJ Wrangler Technical Forum 7 07-15-2006 07:42 PM
Strange starting problem... atomicmoose YJ Wrangler Technical Forum 23 01-22-2006 01:14 AM
