Quantcast Strange Engine Problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Strange Engine Problem
Old 06-11-2008, 06:35 AM   #1
lstuckey1
My '90 2.5 is acting up. I normally drive my jeep locally and it doesn't see the open road very often. A few days ago I had to drive it to the next town and had about 15 miles at highway speeds. I noticed after a short while that the engine seemed to be losing power and seemed sluggish, almost as if something was physically slowing the jeep. Then I started to hear a sound that was kind if like detonation but not quite the same. I seemed more like a rattle than a knock. I backed off the pedal and slowed down and it seemed to subside. When I sped back up it seemed fine then started the noise again. Suddenly the engine shuddered once very hard (shook the whole jeep) and returned to normal. I pulled over, shut it off and looked under the hood for anything obvious. Nothing. When I started it back up it ran fine and I drove it the rest of the way. On the way back it did the same thing.
Since then it has been running great but I only drive it locally and have not stretched its legs much.
This morning I was driving to work (about 3 miles on country roads) and it did exactly the same thing again.
Does this sound familiar to anyone? Sorry for the long story.
lstuckey1 is offline   Reply With Quote
Old 06-11-2008, 06:53 AM   #2
EABiker
A couple things to check; fuel system, when was the last time you changed the filter? Detonation is either caused by too much timing, too little fuel, (lean), or higher compression, (carbon build-up). Also, there is a chance the cat is going bad; it may be falling apart internally and causing exhaust blockage.
EABiker is offline   Reply With Quote
Old 06-11-2008, 07:20 AM   #3
lstuckey1
Thanks for the reply. I’m ashamed to say I have not checked the fuel filter. I bought the Jeep in December and have been doing maintenance since but never changed the fuel filter. Is there another one besides the in-tank filter?
The P/O removed the cat so that would not be the problem. Is there a way to remove carbon build-up? Sea foam?
Old 06-11-2008, 07:39 AM   #4
EABiker
The fuel filter should be external, behind the driver's rear wheel. Seafoam is a good bet to clean the carbon, Another thought I had though was your coil may be having issues when it heats up.
All that should keep you busy for a while!
Old 06-11-2008, 08:14 AM   #5
lstuckey1
Just one more question on the sea foam topic. I've read that you can disconnect a hose or vacuum line and pour this stuff very slowly through the fuel injector. Is this wise? And exactly what hose/vacuum line would one use for this?
Thanks for everything, you've been a big help!
Old 06-11-2008, 09:18 AM   #6
EABiker
I use the brake booster line pinched over a smaller diameter tube that goes into the bottle; that makes it easy to squeeze the tube a bit to slowly add the liquid into the intake, (too much and it will stall out). I also let it sit overnight and do it's magic for the early morning smoke show!
Old 06-11-2008, 06:53 PM   #7
laybackman
laybackman's Avatar
Either you have a clogged fuel filter orrrr a clogged cat converter. Highway speeds bring out the problems in both of them. Do the FF first since it is cheap $$ then road test it.
laybackman is offline   Reply With Quote
Old 06-11-2008, 07:50 PM   #8
Fastbeeatch
I had same thing happen to me I ended up using dry gas took care of my problem. I knew my filter was good and filled it up the morning the problem happened, so it was easy to figure out I got bad gas. Before you change the filter unplug the out line, put a bucket under it and prime it a few times. Water settles to the bottom of the gas tank so it will be the first out, so if that is your problem you'll get a mixture of the two. If it's only gas then you know you can change the filter without worrying about ruining it by running water trough it.
95 4L Auto D300 TC
103" Wheelbase
D60 Front 14 Bolt Rear 4.10 Gears
H1 Wheels 36" GoodYear OZ Tires
Fastbeeatch is offline   Reply With Quote
Glock Forum
