Straight pipes on 4.0 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Straight pipes on 4.0
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 03-29-2009, 07:25 AM   #1
jlarsen2
I just put a straight pipe on my jeep and was wondering what the excessive gas smell could be when i pull it into my garage. What could be the cause???
It smell richer than when i had the aftermarket exhaust on it.
And is this a bad thing or a good thing?
btw it sounds awesome for a I-6
Am i just worried about life
or am i just LOCKED UP
jlarsen2 is offline   Reply With Quote Quick reply to this message
Unread 03-29-2009, 08:02 AM   #2
jeep95xj
1995 XJ Cherokee
its sounds terrible i did it on mine and hated it. do you have a cat? if not thats the answer to your gas smell. also you just cut your gas mileage is half. your motor is dumping a lot more fyel with no back pressure. your plugs and ot sensor wont last long either
jeep95xj is offline   Reply With Quote Quick reply to this message
Unread 03-30-2009, 10:07 PM   #3
jlarsen2
yeah i have a cat but i have not nopticed a severe drop in gas mileage...it was already bad pushin around 13 mpg
Unread 03-30-2009, 10:15 PM   #4
4.7stroker
Put a muffler on that rig, it needs some back pressure to operate properly.
I know you want the whole world to hear you driving down the street but honestly you are not going to impress anyone with a rig that sounds like azz.
Dwayne
4.7stroker is offline   Reply With Quote Quick reply to this message
Unread 03-30-2009, 10:26 PM   #5
sprngrider
A muffler delete is a little different than a straight pipe or test pipe. With a test pipe, you delete the cat, which is bad. A muffler delete is fine and will not cause any mech. problems, but the noise would be too loud for me.
The smell could come from running a little richer because of less back pressure.
sprngrider is offline   Reply With Quote Quick reply to this message
Unread 03-30-2009, 11:30 PM   #6
bryris
A muffler delete? Cat delete? Too funny.
1995 YJ Sahara
bryris is offline   Reply With Quote Quick reply to this message
Unread 03-31-2009, 03:38 AM   #7
sprngrider
Not posting something worthwhile... Too funny.
Unread 03-31-2009, 04:48 AM   #8
JIBTEXHNKA
1987 YJ Wrangler
pointless arguments that make me laugh... priceless
JIBTEXHNKA is offline   Reply With Quote Quick reply to this message
Unread 05-07-2009, 05:25 PM   #9
jlarsen2
suprisingly it does get better the only down side it that it pops if you punch it in either First or sencond gear. what could that be???
Unread 05-07-2009, 09:59 PM   #10
jeep95xj
1995 XJ Cherokee
To much fuel. Very simple solution. If you want more noise and a little more power go with a high flow cat and a good muffler. Your neighbors and local cops will love you for it. A 4.0 is not a performance motor and doesnt sound good with "open headers" and or no muffler.
Unread 05-07-2009, 10:14 PM   #11
sprowley
Dwayne
Preach on brother, preach on
92 YJ Islander Sold!
97 TJ Sport black on black with MT/R Kevlars and lots of new parts coming!
Canon EOS-1D Mark III, Canon EF 70-200mm f/2.8L USM, Canon EF 17-35/2.8L USM, Sigma 50mm f/2.8 EX USM
My Fuelly page (fuel economy and usage tracking)
sprowley is offline   Reply With Quote Quick reply to this message
Unread 10-03-2012, 06:30 PM   #12
87manche17
1987 MJ Comanche
Would it sound like crap on a 87 jeep Comanche, I thought about because it has a lope at idle. I always thought it would sound good to cut the muffler and leave the cat.
87manche17 is offline   Reply With Quote Quick reply to this message
Unread 10-03-2012, 06:42 PM   #13
mrdeath2000
the CAT does provide some back pressure and muffling. Not sure how much on a Jeep, but on an 06 mustang GT I ran no mufflers for the whole 2 years, perfectly fine, sounds good, not obsurd. removing the cat or running a Hi-flow cat will make it stupidly obsurd and you should be shot.
When I switched my 2.5L to a new header, I had a 4" gap I needed branched between the downpipe and the cat -> muffler, sounded like a top fuel lawn mower.
93' YJ 2.5L, 4.88's, 8.8, E-Locker & LSD
mrdeath2000 is offline   Reply With Quote Quick reply to this message
Unread 10-03-2012, 07:21 PM   #14
UltimatE
Resident Audio Guru
UltimatE's Avatar
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
UltimatE is offline   Reply With Quote Quick reply to this message
Unread 10-04-2012, 07:32 PM   #15
87manche17
1987 MJ Comanche
Im running a 4.0, not a 2.5. So i think it would sound better than that.
