Stop leak for heater core leak?? - JeepForum.com
 3Likes
post #1 of 28 Old 06-11-2007, 05:35 PM Thread Starter
alaksaboy
I must have a small leak in my heater core as steam will come out of the defrost and the floor board under the heater is slightly wet. Anybody have success with the radiator stop leak? Did you use one bottle or two?
Thanks
alaksaboy is offline
post #2 of 28 Old 06-11-2007, 05:43 PM
tolcu79
I have used this stuff on a few separate occasions. If the leak is small enough it will stop it. On the other hand if the leak is as bad as you say it is I know that I would just go ahead and change it out. I know that is not what you want to hear but just my honest opinion. If you decide to use the stop leak type stuff, get the kind that you have to drain the antifreeze and run only water to use, (much better than the regular pour in stuff). I know that most mechanics view this type of fix as temporary.
tolcu79 is offline
post #3 of 28 Old 06-11-2007, 05:51 PM
shunt
shunt's Avatar
Replace the heater core. You'll save yourself frustration.
One step beyond................
shunt is offline
post #4 of 28 Old 06-11-2007, 05:53 PM
Wranglerguy
Change it. You'll have to sooner or later anyway.
1993 YJ
2003 TJ
If you can't cut it, don't pick up the knife.
Wranglerguy is offline
post #5 of 28 Old 06-11-2007, 05:54 PM
Rocky529
Rocky529's Avatar
It's not hard in a Jeep... change it out as everyone else suggested. One day you are going to have coolant all over the inside of your Jeep and your engine will be overheating.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #6 of 28 Old 06-11-2007, 06:29 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
After you use it and IF it stops the leak it will only do that for well who knpows before the leak starts again....usually at the worst possible time you will have to go ahead and replace the heater core.....now what do you do with the plugged radiator?
That stuff should be called radiator stop flow. It was invented for crooked used car dealers to move inventory without spending any large $$$ to do so IMHO.
laybackman is offline
post #7 of 28 Old 06-11-2007, 06:38 PM
goatboy
If you have to use a sealer, use Alumnaseal or Silverseal...try a half a container first, a little goes a long way..DONT use two...you'll rue the day, it's really effective stuff...
goatboy is offline
post #8 of 28 Old 12-22-2009, 07:42 AM
jvetter03
So.....I know this is a really old thread, but i have to ask.....what do you do if the previous owner put a few (more than 2) tubes of stop leak in there? ...my buddy is having this problem right now. Thermostat was plugged up, heater core is plugged up...there was even a glob on the back of the radiator cap....WOW..... is there an easy solution to clean all that crap out so that the heater will work again?
1999 Wrangler- Locked 8.8, locked D-30, UCF Belly up, 35 Mud Kings on Crager Soft 8's, 4" SL, 2" BB, 1" MML, 1" BL, Adjustable UCA's, Adjustable LCA's, Terra SYE, DC-DS, Smittybilt Tube Fenders, Quick Disco's, Rhino Lined Tub, Neoprene Seats, Marine radio/CB, 4 KC's, Smittybilt XR8[/COLOR]
jvetter03 is offline
post #9 of 28 Old 12-22-2009, 07:52 AM
jbolty
jbolty's Avatar
flush, back flush, flush again. run it for a while with flushing solvent in it then flush it again.
worst case you are looking at a new rad and heater core but make sure the block is all cleaned out first or you will be back in it again.
while you are at it do a compression test. the PO might have been trying to hide a bad head gasket.
good luck.
jbolty is offline
post #10 of 28 Old 12-22-2009, 08:15 AM
Louie4
To answer your question, no I have never had any success with any type of stop leak. Just replace the leaky part like these said. It's the only way to be sure.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #11 of 28 Old 12-22-2009, 11:37 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
I agree. he stuff is supposed to clog up leaks in a rad or heater core.
If your system is old enough to have leaks spring in it, it is also partially glogged no doubt. Stop leak may not fix the problem but it will add to the 'gloggage' IMHO.
BTW Old timers used to use cinnamon or ground black pepper to 'fix' leaky radiators. I saw (actually smelled) a rad leak that was temporarily repaired (small leak that is) using cinnamon.....smelled pretty good also!
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
post #12 of 28 Old 12-22-2009, 11:46 AM
Louie4
I heard of some people putting a raw egg in then running the motor?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #13 of 28 Old 12-22-2009, 02:06 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
I have heard of that one also but I would not trust any 'stop leak' goo in my cooling system. And, if it is good enough to plug up a leaky rad or heater core, it might be good enough to plug up a water passage in a head or block or another section of the rad or heater core that is already narrowed out by crud from age.
post #14 of 28 Old 12-22-2009, 03:50 PM
93jeepyj
My buddy put some alumnaseal in his truck in about november to fix the same issue and it worked for about a week and was leaking again. Last week I helped him change the heater core which was fun, it was an 03 dodge ram and everything had to come out even the steering column had to be dropped. when we got it out the hole was only about the size of a pin... I think id just change it and not run the risk on clogging passages for something thats only a temp fix. You can always bypass the heater core until you have the time to do it.
93jeepyj is offline
post #15 of 28 Old 12-23-2009, 07:45 AM
jvetter03
good luck.
Thanks. I'll go down to the parts store after work and grab another one of those plastic T's so that I can back flush the radiator too...what type of solvent works best?
Heater core leak fixed drew2000 YJ Wrangler Technical Forum 2 05-25-2009 03:09 PM
Possible Heater Core Antifreeze Leak Question bblhead TJ Wrangler Technical Forum 8 02-03-2009 09:55 PM
Heater core leak? Fred007 YJ Wrangler Technical Forum 4 11-29-2008 08:35 AM
Does radiator stop leak clog the heater core? durangoyj YJ Wrangler Technical Forum 4 11-13-2007 10:02 PM
Radiator stop-leak in heater core? Achped TJ Wrangler Technical Forum 7 11-27-2005 02:42 PM
