Stock YJ Wheels for my 93 - JeepForum.com
post #1 of 4 Old 05-17-2010, 09:00 AM Thread Starter
LFThomas
Guys & Gals - I have a 93 YJ, 6 cyl. I have had since new. In the past I changed the wheels, now I want to go back to the stock steel wheels (which of course I gave away). Can anyone help me with the years that the wheels were the same? So as I search for them I will know which will fit and that the backspacing will be the same as stock. I really prefer to stick with the 15", the look is not as important as the correct backspacing and dimensions of my original wheels.
Thank you.
LFThomas
LFThomas is offline
post #2 of 4 Old 05-17-2010, 09:04 AM
YJake
Jeep cherokees used the same stock wheels. I see them all the time in junkyards, cheap too.
Jake
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #3 of 4 Old 05-17-2010, 09:32 AM
K4KAS
87-2006 Wranglers have the same bolt pattern and will fit. Little differences such as width and diameter. I cant say which yrs of Cherokees will fit but do know a lot of them will.
K4KAS is offline
post #4 of 4 Old 05-17-2010, 09:37 AM Thread Starter
LFThomas
Jeep Stock Wheels
Thanks guys, this helps!
LFThomas is offline
jeep yj , steel , stock , wheels
Stock tj wheels.. RVA_TJ06 TJ Wrangler Technical Forum 7 07-10-2008 01:03 PM
What stock wheels are these?? PIC bman9089 TJ Wrangler Technical Forum 40 07-04-2007 05:57 PM
stock wheels gokusgrill YJ Wrangler Technical Forum 7 04-04-2007 01:58 PM
Stock wheels zaq123 TJ Wrangler Technical Forum 2 05-11-2005 12:45 PM
Will the stock wagon wheels (15x7) with 31x10.50 tires fit on without wheels spacers? BIGCRAZYBELL TJ Wrangler Technical Forum 4 11-28-2004 12:10 AM
