stock shackle question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > stock shackle question
Build your Dream Jeep with Poison Spyder's Interactive GarIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 08-18-2012, 07:02 AM   #1
jasjeep08
Hello, I've been reading differant threads on leafs and shackles, and at the moment I can't afford to replace them. What I was wondering can the shackles be loosend up and adjusted to give more bend to the leaf springs? If so how is this done?
My rear leafs are flat and the front has a little bend and the shackles look to be angled forward.
my yj is going to the body shop to have that famous rear right frame welded, there's a crack there (rear shackle location)
Theses are stock and it's my daily drive, no plowing or towing haven't even gone off road yet...
jasjeep08 is offline   Reply With Quote
Unread 08-18-2012, 07:15 AM   #2
krabby124
The shakle lift is cheap and easy to do. You can find a set on ebay or craigslist for around $50 and they are easy to put in. They dont raise it a ton but you do know the differnce and you can clear 31 inch tires with no problem. I think it would be the cheap road while doing a little upgrade to the jeep aswell
Sent from my DROID4 using JeepForum
XJ Build Thread [url]http://www.jeepforum.com/forum/f22/high-school-xj-build-1332206/[/url]
YJ Build Thread [url]http://www.jeepforum.com/forum/f22/95-high-school-yj-build-1411192/[/url]
krabby124 is offline   Reply With Quote
Unread 08-18-2012, 07:33 AM   #3
jasjeep08
I think I seen those but in differant size, what size should I get? What you said sounds perfect. Is there a kit for this, that will come with what I need.
Unread 08-18-2012, 09:56 AM   #4
Anticanman
Anticanman's Avatar
I don't think I'm understanding your question. When you say "more bend to the leaf springs" are you looking for more lift or more travel for the leaf springs to flatten? If you install shackles that are too long, your leaves will bend in the opposite direction and will not flex well at all. On the other hand, if your springs have an arch to them, it takes more travel to flatten them and longer shackles to achieve said travel. Design also helps.
How abouts I just shut up and throw you a link?
http://www.jeepforum.com/forum/f12/t...ackles-1379950
Edit: I understand your question now. You're looking to loosen up the shackle to rearch your spring. It ain't gonna happen. Once you're flat, it's flat. It's like tuning your valve stem cap to reinflate a tire with a gaping hole in the sidewall.
Luck favors the prepared
Originally Posted by squarelight94 View Post
You're the Oprah of jeeps, slap your name on it and it sells like hot cakes!
Originally Posted by jbolty View Post
I would like to thank everyone who thanked Anticanman.
Originally Posted by egodfrey
Well canada is a different story this is american talk here silly :rofl:
Anticanman is offline   Reply With Quote
Unread 08-18-2012, 03:58 PM   #5
jasjeep08
I wasn't thinking about changing the shackles, I was looking to get more bend in my leaf springs, so I should have been more clear. I thought if you moved the shackles that would give more bend. Guess I'll look for a add leaf kit.
