Stock Lockers - JeepForum.com
post #1 of 6 Old 06-23-2006, 09:35 PM Thread Starter
Ares
Ares's Avatar
Stock Lockers
Quick newb question here. I read that the Sahara had a rear locker OPTION in 1992 with a standard feature LSDs front and rear. However the following year 1993 it just said the Sahara had all options. Does this mean from 1993 on it had a rear locker as a standard option, or was that a typo and suposed to be Limited Slip Diff? Just asking because its a deciding factor in a kicked-in-the-face 1994 Sahara whether to get it or not. Any help is great.
Also if you have any diff codes...those would be great too.
Ares is offline
post #2 of 6 Old 06-23-2006, 10:17 PM
ks03rubicon
The 1st and only Jeeps ever that came with lockers from the factory were the 2003 Rubicons. Any Jeep that has lockers before then (or any other Jeep model) would be aftermarket.
2003 Rubicon (Khaki),
3 1/2" Rubicon Expess lift, Currie Anti-Rock swaybar,
305 MTR's, Skid Row engine plate, Warn M8,000# winch.
ks03rubicon is offline
post #3 of 6 Old 06-23-2006, 10:26 PM
Jakemd98
Choosy moms choose jeep.
Jakemd98's Avatar
LSD rear in a D44 tj from factory... dont know about YJ though
Jake Davis
97 Jeep Wrangler
4.0, 5 speed AX-15, D44 & Ford 8.8 w/Detroit - 4.88, NP-231, OME 2.5" coils w/1.25" spacers on front, 1.25" JKS BL, 35X12.50R15 KM2 on 15x8 Eagle alloys, Banks Header, Banks Monster Exhaust, Brown Dog MML, Rhino Liner, Tuffy Glove Box, AtoZ Rockers, Optima Red Top Battery.
1998 GMC Yukon
Jakemd98 is offline
post #4 of 6 Old 06-23-2006, 11:16 PM
Bgeddes
Bgeddes's Avatar
1978 CJ5
I asked a similar question a while back. From what I understand the Saharas had a LSD as an option. My '88 definately has it.
'00 XJ Classic > Stock DD
'88 Grand Waggy - Bone stock pseudo-barnfind
'78 CJ5 - Under minor rehab
Bgeddes is offline
post #5 of 6 Old 06-24-2006, 01:27 AM
jipjip
jipjip's Avatar
there was an option on the yj's for a rear LSD in the D35 which they called a trac-loc or something like that. it would sound to me like a locker, but it's just a LSD. you can tell by the tag on the housing, or raised both rear wheels off the ground, and while turning one, if they both spin the same direction, it's LSD....if they spin opposite directions, it's open.
95 yj sahara green w/ spice hard and soft top, bikini top,full steel doors, and 2 piece bestop soft doors,tnt customs front tube fenders w/ 6" flare,warn gas tank skid, skidrow oil pan skid,4.0HO,rear 31 spline 8.8 w/ disc brakes,4.10's and lsd,front HP d30 w/ 4.10's and aussie front locker,ax15,np231j w/ jb conversions ss sye, tom woods custom cv d/s,RE 4.5xd,35" toyo open country m/t's, 1" daystar body lift, warn 9.5ti
jipjip is offline
post #6 of 6 Old 06-24-2006, 01:54 PM Thread Starter
Ares
Ares's Avatar
Thanks for all the quick replys guys. Helped clear that up fast. Unfortunitly, it looks like this Sahara has a tweaked frame (previous owner rolled it before deal repossessed). It would need a lot of body work which isnt a big deal on the Wrangler (so nice how everything just comes off), but the frame is bent bad enough to where the doors dont line up right anymore, so I doubt it can be aligned within spec enough to have 4wd work properly either
Ares is offline
New gears with stock lockers? USMCEOD TJ Wrangler Technical Forum 6 01-24-2010 10:40 PM
Rubicon Stock Lockers??? XJ Rocker TJ Wrangler Technical Forum 3 06-02-2008 11:32 AM
lockers in Stock axles Poke YJ Wrangler Technical Forum 14 05-30-2008 10:19 AM
lockers and stock axles? vtjeepguy97 TJ Wrangler Technical Forum 11 04-27-2008 11:51 PM
Lockers with stock gearing and D35&D30 Justin'sJeep10 TJ Wrangler Technical Forum 33 08-28-2006 12:47 PM
