stock gears in an 89 YJ - JeepForum.com
post #1 of 15 Old 10-18-2002, 12:33 PM Thread Starter
freak4jeeps
freak4jeeps's Avatar
anyone know what a stock 89 2.5L 4 cyl YJ may have , I know the geas have never been altered. I am jsut trying to find out because I want to run 33's and need to know if it will be able to handle it with the stock axles and diff's with no adjusments right away.
I do plan on swapping in a currie 60 in the rear and a 44 hopefully from a yard somewhere later on down the line, but those are future plans.
The jeep isnt a road jeep its being built just for trail so I am not worried at all about how it will react on the road, except maybe for short distances.
98ZJ 4.0
  • RE3.5" Super Flex
  • 32" BFG ATs on 15x8 Hellcats
  • JKS Quicker Discos
  • Adj. Tbar F/R
  • Flow 40 Series
  • Kevins Sliderz
  • Custom Front Bumper(Fab'd up by a tree)
you don't need lockers.
Got
freak4jeeps is offline
post #2 of 15 Old 10-18-2002, 12:41 PM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
Should be 4.10's as long as know one else changed them before.
Life is tough enough already, but it's even tougher when you're stupid
Devious is offline
post #3 of 15 Old 10-18-2002, 08:54 PM
Buzzard
Hey Freak4, have you ever been to that place in Framingham called Cheap Jeeps? Is it any good? What kind of place is it?
Buzzard is offline
post #4 of 15 Old 10-18-2002, 11:11 PM
jthumper35
I also have an 89 Yj and I am still curious as to what gears i am running. I have the 258 cid engine and i was wandering how i could tell what gears i have on my rig??
89 YJ, stock 258 cid ,carter 2bbl , 4 inch superlift suspension system, 31" BFG All Terrains, Flow Pro Exhaust, and some more interior extras
jthumper35 is offline
post #5 of 15 Old 10-18-2002, 11:16 PM
Lavacrawler
Lavacrawler's Avatar
If your pumpkin still has the little metal tag you should beable to tell from the first 3 numbers, from what I've been told. Hope this helps some.
99 TJ
62 CJ5 Willys
88 Sami
89 Yamaha TW200
Lavacrawler is offline
post #6 of 15 Old 10-19-2002, 08:07 AM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
jthumper35, you R&P should be 3.08, a friend of mine has a '87 yj and that is his ratio.
Devious is offline
post #7 of 15 Old 10-19-2002, 01:31 PM Thread Starter
freak4jeeps
NO buzzard never been there, never even heard of it. But i will have to look into it and see what you are talking about.
98ZJ 4.0
  • RE3.5" Super Flex
  • Adj. Tbar F/R
  • Flow 40 Series
  • Kevins Sliderz
Got
post #8 of 15 Old 10-21-2002, 08:43 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
With the 258 engine there were three choices for gears .. my Jeep came with 3.73 gears .. I know that 3.54 gears were an option .. and the standard gear was 3.07. The difference was in the package from the factory ..
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #9 of 15 Old 10-21-2002, 10:15 AM
jthumper35
I dont know what package came on my jeep but i know it wasnt the standard package. Mine came with hard top, full steel doors, ac, and tilt wheel, automatic 4x4(very rare).
Just my .02 cents
post #10 of 15 Old 10-21-2002, 10:35 AM
NaeKid
NaeKid's Avatar
Does it say Laredo on the decals on the sides???
If it does, you would have the 3.54 or the 3.73 gears. Do you have the factory towing package???
If it does, then you would most likely have the 3.73 gears.
My 1988 Laredo came with factory towing so it had the best gears available from the factory .. the 3.73 behind the 6-popper.
Silver
NaeKid is offline
post #11 of 15 Old 10-21-2002, 07:22 PM
93jeepyj2.5
93jeepyj2.5's Avatar
Naekid,
I'll answer one of those questions for you......Jthumper35 doesnt have a Laredo.
But he does have some sort of towing package, not sure if its stock or not though???
-Heath
93 Black YJ, locked and on 33's----Sold
03 TJ Sport.....31" MT/R's on MT Classic II's
93jeepyj2.5 is offline
post #12 of 15 Old 10-21-2002, 11:47 PM
Mudpig
Having a Laredo doesn't necessarily mean you get 3.54 or 3.73. My 89 came with 3.07s.
It's a jeep thing, I do understand!! 89 YJ Laredo,4.2L carburated. Chrome bumpers and grill. 31 AT's on 9x15 chrome modulars. Mustang GT buckets. 3" body lift and 1 1/2" shackle lift. Completely emission & computer free. Runs great!! Took the shackle lift out, they suck!!
Soon to be SOA with 35's
Mudpig is offline
post #13 of 15 Old 10-22-2002, 10:49 AM
NaeKid
NaeKid's Avatar
Mudpig ..
Thanks for that piece of information .. my understanding from other Canadian Jeepers was that the Laredo had the better gears as part of the factory package. Maybe in the states its a different story .. <shrugging shoulders>
Silver
NaeKid is offline
post #14 of 15 Old 10-22-2002, 10:51 AM
jthumper35
Sorry guys for not posting a reply and leaving yall in the dark. I do have a towing package on my jeep. It's not a Laradeo but still not sure what gears are on it. Could i take my vin number to my nearest Jeep dealer and check it out? I also have a sticker under my hood that has my specifications but im not sure if it says what gears. Ill look and see if that sticker shows it.
i appreciate all the help guys
post #15 of 15 Old 10-22-2002, 11:16 AM
RCHavok797
RCHavok797's Avatar
jthumper have you checked the diff tags yet? That it the easiest way to tell unless the previous owner changed them.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
Stock gears vs. gears for 35's RustedWrangler YJ Wrangler Technical Forum 6 08-14-2009 12:04 AM
stock gears jeeping18 TJ Wrangler Technical Forum 7 02-20-2009 01:09 PM
stock gears? Orrtannaboy13 YJ Wrangler Technical Forum 3 03-12-2008 12:35 PM
OK, how bad is it really it go with 33s and stock gears? hipmatt TJ Wrangler Technical Forum 31 06-06-2004 02:05 PM
stock gears easttexan54 TJ Wrangler Technical Forum 6 05-05-2003 06:06 PM
