stock gear ratio - JeepForum.com
post #1 of 2 Old 08-30-2014, 07:30 PM Thread Starter
jsis789
stock gear ratio
hey, I have an 89 YJ automatic and was under the impression I had the 3.54 gearing from reading this from several different sites including this one. so without checking I purchased an Eaton tru-trac for the rear. while getting ready for the swap i decided to spin test and as far as i can tell i have 3.07 ratio even quadratec lists autos as having 3.55 ratio. it does state "normally" on this site with no other ratios listed but according to Jeeps VIN checker 3.07 is standard gearing. I cant believe im the first to have this problem. luckily enough i found a set of rears with 4.10 gearing pretty cheap but i am only running 31 10.5 15 and thought 3.55-3.73 would be better for my highway driving.
jsis789 is offline
post #2 of 2 Old 08-30-2014, 10:02 PM
yellow2kgt
You are not the first. I am not sure why everyone lists the autos as having 3.55s. My YJ auto came stock with 3.07s as well. From my experience it seems like most autos were the same (my sister's 01 TJ auto also has 3.07s.)
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is offline
