Stock axles on 35's?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Stock axles on 35's??
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 12-16-2011, 11:00 AM   #1
OleSteepJeep
Thinking about going up from 33's to 35's. Is anyone running 35's with stock axles? If so are you having any problems with them?
OleSteepJeep is offline   Reply With Quote Quick reply to this message
Unread 12-16-2011, 11:06 AM   #2
Michaelgoesrawr
Michaelgoesrawr's Avatar
It really depends on how you drive it. Some people get away with wheeling 35's on the d35 but sooner or later something will break.
Michaelgoesrawr is online now   Reply With Quote Quick reply to this message
Unread 12-16-2011, 11:20 AM   #3
YJames90
Yes, They will not self destruct when pulling out of a gas station
My 2.5 to 4.3 swap thread
http://www.jeepforum.com/forum/f12/4...begun-1237704/
YJames90 is offline   Reply With Quote Quick reply to this message
Unread 12-16-2011, 12:29 PM   #4
Spuznick242
But I saw one go when a friend of mine took out too fast on a steep grade...kinda funny watching him replace an axle shaft before he even hit a trail...but to the OP dont be "that guy" in this case and run 35s on the D35, its not worth it.
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline   Reply With Quote Quick reply to this message
Unread 12-16-2011, 12:58 PM   #5
YJames90
I ran 35s on a locked 35. but were not here for that age old discussion
Unread 12-16-2011, 12:58 PM   #6
jhumphrey
Simple answer: don't.
http://www.jeepforum.com/forum/f59/b...-pics-1089812/
http://www.jeepforum.com/forum/f19/d...ke-one-351060/
http://www.jeepforum.com/forum/f12/b...-35-a-1138589/
http://www.jeepforum.com/forum/f12/please-help-1138370/
There are many many posts on here about the dana 35 and 33" or 35" tires. Im planning to go to 33s in the future, but Im also about to put the Ford 8.8 in. I feel like the d35 is going to break if I look at it hard enough. Jeep should've never been allowed to have installed them in the first place....
You can also find a post by Xpress where his went out while he was driving down the freeway. d35 = crap.
jhumphrey is offline   Reply With Quote Quick reply to this message
Unread 12-16-2011, 01:18 PM   #7
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
I blew mine up on 33 AT's.
I would say its a bad idea to run 35's on a dana35
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is online now   Reply With Quote Quick reply to this message
Unread 12-16-2011, 01:27 PM   #8
SnowYJ
1988 MJ Comanche
My thirty fives give my axles a good workout just driving around town
I go to college and I drive a Jeep.
SnowYJ is offline   Reply With Quote Quick reply to this message
Unread 12-16-2011, 01:37 PM   #9
94chb
since you have a c clip 35 its gonna break real easy and then your axle is gonna slide out. i broke one with 31's i have a bolt in 35 and it seems they are slightly stronger and if i break a axle, my axle wont slide out and i still can drive it home and fix it.
and another thing you need to consider is those 35s with your stock 3.07 gears is gonna suck your not gonna have any power. my opinion for the cheapiest way is to find a 4.10 front end from a 4 cyl model and install it then install a 8.8 from a ford explorer with 4.10s then you will be set and shouldnt have any issues.
94chb is offline   Reply With Quote Quick reply to this message
Unread 12-16-2011, 02:09 PM   #10
Collin89Sahara
Upgrade.
Collin89Sahara is offline   Reply With Quote Quick reply to this message
Unread 12-16-2011, 02:32 PM   #11
Anticanman
RIP one good jeeper
Anticanman's Avatar
Sometimes they break when you're pulling out on the street. On 31's.
Luck Favours The Prepared
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 12-17-2011, 10:23 AM   #12
jhumphrey
That sounds like a story I'd like to hear
OP: I have a non-c 35 in my jeep for now. I have the 8.8 in the garage, I just have to finish getting all the pieces and parts together for the swap...going 4.56 for 33" . Unless you have an auto, 4.56 is the way to go...forget 4.10, Especially if your going 35s in the future.
"A woman's body is a work of art. A man's body is a utilitarian. It's for gettin' around. It's like a Jeep." - Elaine Benes
Unread 12-17-2011, 02:30 PM   #13
Anticanman
RIP one good jeeper
Anticanman's Avatar
Originally Posted by jhumphrey View Post
That sounds like a story I'd like to hear.
http://www.jeepforum.com/forum/group...-35-assassins/
Unread 12-17-2011, 05:16 PM   #14
nathanninja
You're not supposed to. But I am until I finish building my 8.8. It's been on 35s and a d35 since I bought it. I'm a relaxed driver so I'm pretty careful with it. However, my ring and pinion are chipped up to death, I'm not sure if it was like that when I bought it, or if running the 35s did it. But I've put a good 1000 miles on since I found out about the chips, and it's still spinning away. Upgrade if you can, but you CAN run them. It's just not a good idea because it's so unpredictable.
nathanninja is offline   Reply With Quote Quick reply to this message
