still needing tc drop after sye and other sye questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > still needing tc drop after sye and other sye questions
KOR Name Your Price SaleThe Original 3/8" Ruffstuff Diff Cover!Steering and more from Ruffstuff!
Unread 03-30-2014, 09:24 AM   #1
dvsyj
Hi all thanks for any help you can give...I got a 92 yj with a 4" re lift and .5" boom shackles and 1" mml...just installed aa sye and tw shaft... Set pinion with 8 shims as that's the largest I could find and were recommended, I got my pinion 2 below shaft angle and it drives great...but I had to leave a 1" tc drop in...if I removed it my angles were too much..just wondering if anyone has heard or had that issue.. I was really hoping to get rid of that dang tc drop..could it be my springs need to still settle in and I could possibly remove it in time or my tires being 31s be too small..I think a larger tire would raise diff up a bit maybe? Another thing I know cutting and rewelding perches is most advised but not a possibility at the moment...another question is now my diff has quite an angle on it from the shims, would it be good to get an aftermarket diff cover to give it a little more fluid capacity, I really don't want blow my pinion bearings from lack of gear oil...thanks for any advice ahead of time
dvsyj is offline   Reply With Quote Quick reply to this message
Unread 03-30-2014, 09:59 AM   #2
bpounds
bpounds's Avatar
You didn't mention a problem with vibrations. Did you have that? Or do you just not like the angles? Proof is in the pudding.
Tire diameter has nothing to do with driveline angles.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline   Reply With Quote Quick reply to this message
Unread 03-30-2014, 10:01 AM   #3
dvsyj
No vibes at all, all is perfect, just HAVE to keep the tc drop in.. If I remove it the angles would be too much at the differential...
Unread 03-30-2014, 10:07 AM   #4
Anticanman
Follow me
Anticanman's Avatar
Why would it be too much at the differential? I don't get it
Luck Favours The Prepared
[SIGPIC][/SIGPIC]
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 03-30-2014, 10:09 AM   #5
bpounds
bpounds's Avatar
Exactly. I think you're hung up on specific angles, instead of the results. The driveline angles are going to be different on each truck.
Take the drop out and go for a drive.
Bill
Unread 03-30-2014, 10:14 AM   #6
dvsyj
Alright will do...what I met by the angle at the diff was the angle would have been more than 2...I'll take it out and see how it is...I guess I was hung up on the angles on paper, so to say
Unread 03-30-2014, 10:20 AM   #7
The_Goob
Hell on Wheels
The_Goob's Avatar
mine is sitting at 4* below pinion and I can comfortably drive 45, any more and the vibes are getting me. I have a MML on the way. that's 20.5*pinion and 24.5* driveshaft. I messed up when putting on perches
The_Goob is offline   Reply With Quote Quick reply to this message
Unread 03-30-2014, 01:13 PM   #8
dvsyj
OK took out the tc drop and I'm at 15 pinion and 23 driveshaft...get the vibes pretty good at about 40 mph...guess I'm stuck with the drop then right? At least til I might be able to get the rear perches rewelded then right..
Any input on using a higher filling differential cover to keep the pinion bearings lubed? Thanks again guys
Unread 03-30-2014, 01:21 PM   #9
bpounds
bpounds's Avatar
Was hoping that would not be the result.
Would be interested in seeing a side view pic of your rear driveline.
Can't help on the lube level.
Bill
Unread 03-30-2014, 01:42 PM   #10
dvsyj
Its not letting me post pics from my phone... Let me go inside..
Unread 03-30-2014, 02:16 PM   #11
dvsyj
This is with the tc drop pinion at 15* shaft at 17*img_20140323_200144-2.jpg
this is without tc drop pinion still at 15* shaft at 23*. it dosent look so bad in the pic, ill try and get anotherimg_20140330_113752-2.jpg
Unread 03-30-2014, 02:26 PM   #12
bpounds
bpounds's Avatar
I don't know what to say. They both look good to my eye.
Bill
Unread 03-30-2014, 02:30 PM   #13
dvsyj
ya it dosent look as bad from the pics, but its noticeably off just looking at it...like 8* off an the angle finder.. no worries ill just use the drop for now and i appreciate you taking the time to look...
Unread 03-30-2014, 02:49 PM   #14
dvsyj
stupid tc drop sorry
Unread 03-31-2014, 03:15 AM   #15
JCashen
So without the drop is the pinion pointing above the transfer case output? Without the drop you might try shims with less degrees to bring the pinion down some.
"Drippy"
90 YJ 5.2 Magnum, 4.10 LSD 8.8
JCashen is offline   Reply With Quote Quick reply to this message
