Jeep Enthusiast Forums banner
Still having engine trouble.
906 views 11 replies 4 participants last post by  mgkbull
#1 ·
So my YJ has been steadily running worse. It's the holiday season and cannot afford a mechanic at the moment, so I'm hoping I can fix this myself as well.
When first getting the thing started it chugs a bit and then smooths out. It'll sit there and idle just fine all day long. Soon as I start going up some hills though, under load, it starts bogging down. I smell gas and then it dies. It also uses a lot of RPM's. Usually I shift to third right when it's at 2k rpm and at 30mph. Now I can shift to 3rd at 20mph. Timing?
And then, after it's bogged down, I pull the air cleaner off and see a huge cloud of white vapor/smoke coming out of the carburetor. It just sits there until I blow it away. What is this white stuff?
And thennnn, there's this guy:
It's a very rusted (surprised here because cars don't rust in New Mexico lol) pipe right next to the main exhaust pipe. I noticed it because there was smoke coming from the side of my Jeep and it smelled very "gasy". What does it do? Could this be the source of my issues performance wise?
Thanks in advance folks.
See less See more
1
#3 ·
Hrm, that' weird. I'm not real familiar with the carbed jeeps, but I know the white fog you saw when it sputtered out, is normal for a carb when it sputters out. That's just your gas-air mix that the carb was doing. Just don't smoke around it!
Far as the pipe, one of the other guys is gonna have to help with that one - its not the stock exhaust? I dunno.
#4 ·
BTW it might be a real good idea to get a carb rebuild kit and some carb cleaner. I used to do a lot of GMC carbs.... some experience with carbs there. Its running way too rich, judging by the plugs and the gas smell. You can prolly redo the carb and re-adjust it for less than $30.
#5 ·
the rusted out pipe is connected to the catalytic converter and is part of the emission system. it should connect to a check valve that is connected to the air cleaner. You should look into getting the carb rebuilt. I got tired of rebuilding my carb and always adjusting the choke so I switched this year to fuel injection.
#6 ·
I wish I could afford getting a FI. I just rebuilt this carb in July. Shouldn't need it again that quickly! Thanks for the info on that pipe. So is it important that I get that fixed, other than it just smelling bad?
What's the best resource for tuning that carb? Anyone got a link?
#7 ·
You need to repair or remove the pulse-air system (the rusty pipes in the photo). They are allowing unfiltered air into your carb, not good.
Check that your Idle tubes aren't leaking. (google "Carter BBD idle fix " if you aren't familiar with this common problem).
Tuning the carb can go 2 ways. Do you have emission inspections ?
#9 ·
I'm reading the "Fix for Idle problem" and have noticed something different about my Carter BBD carb. When I hit the gas, gas comes out of the Venturi tubes, but also some comes out in between them. Is there a separate tube that injects gas into the system?
#11 ·
OK, I just pulled the carb apart again and adjusted the float level and pulled the stepper motor out some more. Still running with high RPM though. Idle is fine, runs smooth. But when driving I can shift to third at 2k rpms at only 25mph. Again, usually it takes me to hit 30mph before I hit 2k rpms. it's better than where it was, at 20mph. So I've done something right?
Top
