still cannot charge my ac - JeepForum.com
post #1 of 11 Old 06-25-2013, 07:18 PM Thread Starter
rubisean
so here is what i have done so far, new compressor, pressure switch, system flush and conversion to 134a. i pull vacuum for 15 minutes and hold for another 15, then inject oil. after that i try to charge with 2lbs. and none will go into the system. i have tried to jump the compressor in an attempt to get it to accept the freon to no avail. the clutch does kick in and out when jumped. could a bad dryer or expansion valve be my problem? thanks in advance
rubisean is offline
post #2 of 11 Old 06-25-2013, 07:19 PM
Louie4
Did you open the valves on the compressor? There are studs on the back where you open them by screwing them in.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 11 Old 06-25-2013, 07:23 PM Thread Starter
rubisean
yes they are both open, thanks
rubisean is offline
post #4 of 11 Old 06-25-2013, 07:53 PM
superj
I only open the side the freon goes in when I do mine.
But for the problem you have, I am stuck man. You have done everything I would have tried so I have no idea. I forgot everything related to ac systems I learned in tech school 13 years ago.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #5 of 11 Old 06-26-2013, 05:32 AM
Louie4
Did you put the proper drier in? I know when I ordered a new one they gave me the wrong style but it was for a YJ.
Other than that I'm stumped. Did you replace the expansion valve?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #6 of 11 Old 06-26-2013, 10:55 AM
OhMY95yj
Are the 134a adapter pushing the schrader valves open on the r12 ports?
Regards:
Rey Best
OhMY95yj is offline
post #7 of 11 Old 06-26-2013, 05:56 PM Thread Starter
rubisean
just for kicks i will buy two new retro adapters in an attempt to eliminate one more possible cause. thanks
rubisean is offline
post #8 of 11 Old 07-21-2013, 11:24 AM
Louie4
Did you ever get this resolved?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #9 of 11 Old 07-21-2013, 12:54 PM
WV95YJ
If I remember correctly, the valve you have to open up has backwards threads(Turns clockwise to open the valve and counter clockwise to close) mine doesn't even have Schrader valves. Charge using the low pressure side(the larger diameter line) and keep the high pressure line closed.
WV95YJ is offline
post #10 of 11 Old 07-21-2013, 01:40 PM Thread Starter
rubisean
yes, i finally got it resolved..... ice cold ac 45* at the vents, almost too embarrassed to admit what the problem was. i was certain that i had the valves on the top of the compressor opened, turns out i had them closed. here is the part that baffles me. when i replaced the compressor i made sure i knew the orientation of the valves by physically looking inside of it when it was off the compressor. so by my own assessment i was positive the valves were open and never gave it another thought. the moral of my story is if you "think you know" you probably don't know.
rubisean is offline
post #11 of 11 Old 07-21-2013, 02:24 PM
Louie4
Glad you got it fixed.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
