Stiff Shifter - JeepForum.com
post #1 of 67 Old 06-01-2013, 06:31 PM Thread Starter
CBinDC
Stiff Shifter
Today while cruising around town I was finding it increasingly difficult to get the shifter into gear. I've never had this problem before. Does it need oil? I hope it's something that simple. If so, how do I check the oil, drain old oil, and refill? What type of oil do I use?
Thanks.
CB
CBinDC is offline
post #2 of 67 Old 06-01-2013, 08:02 PM
Mark05059
check the fluid in the master cyl.. if its low then you have a leak that needs to be found.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 67 Old 06-01-2013, 10:05 PM Thread Starter
CBinDC
Where is the master cylinder?
CBinDC is offline
post #4 of 67 Old 06-01-2013, 10:15 PM
caoboy
Engine bay, driver side. Right by the brake master cylinder. Little reservoir.
caoboy is offline
post #5 of 67 Old 06-01-2013, 10:17 PM Thread Starter
CBinDC
The little silver (at least mine is silver) reservoir in front of the brake booster?
CBinDC is offline
post #6 of 67 Old 06-01-2013, 10:43 PM
SuperMidget
it will be on the firewall beside/behind the brake booster.. something like this
SuperMidget is offline
post #7 of 67 Old 06-01-2013, 11:27 PM
caoboy
No, that'd be your brake master cylinder reservoir. You should check on that too while you're at it, won't hurt anything lol.
caoboy is offline
post #8 of 67 Old 06-02-2013, 12:02 AM
mudsweatNgearz
1987 YJ Wrangler
My shift lever gets stiff sometimes too. I need the wife to help me get it in the proper slot when that happens..lol.
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
post #9 of 67 Old 06-02-2013, 12:12 AM Thread Starter
CBinDC
Bazinga! LOL
CBinDC is offline
post #10 of 67 Old 06-02-2013, 05:12 AM Thread Starter
CBinDC
That's what it's looking like. Any thoughts?
CBinDC is offline
post #11 of 67 Old 06-02-2013, 05:16 AM Thread Starter
CBinDC
How does that look to you? Might as well ask while I'm at it.
CBinDC is offline
post #12 of 67 Old 06-02-2013, 05:50 AM
befumo
Fill the clutch master cylinder before it gets too low and you have to bleed it out. Might be air in the line either way.
'89 YJ Wrangler - Sold
'95 ZJ Orvis Edition
'89 YJ Islander
befumo is offline
post #13 of 67 Old 06-02-2013, 05:56 AM Thread Starter
CBinDC
What do I fill it up with and how do I bleed it? By this do you mean drain the oil out first, then refill?
CBinDC is offline
post #14 of 67 Old 06-02-2013, 06:26 AM
RustedWrangler
CB,
You should have an internal slave cylinder, so look underneath at the driverside of the transmission you will see a metal line (looks kind of like a fuel line) that has a fitting on the end, it sticks out of the bell housing a few inches.
Add fluid up top to the round reservoir in your photos (DOT 3 brake fluid).
You will need someone to help push in the clutch pedal while you turn the fitting to let out some air/bubbles. Just like bleeding brakes.
I would go ahead and change the trans fluid as well, I think you have the BA10 trans, if so here is a good write up.
http://www.jeepforum.com/forum/f12/h...ite-up-652142/
www.RCPFA.com
RustedWrangler is offline
post #15 of 67 Old 06-02-2013, 06:38 AM
Joe100
Another thing.
Hi! All
I had the same problem so bad, the PO had broken the TC shifter knob right off and said he never moved it except 4 wd high and 2 wd never knew about theneutral and 4 wd low. I had to take the rubber boots off and use Kroil to barake it loose enough to be able to shift it and I've been lubing it every once and awile since no more shifter problems. Good luck to you Joe100
Joe100 is offline
