-   -   Stiff Shifter (http://www.jeepforum.com/forum/f12/stiff-shifter-1531109/)
CBinDC 06-01-2013 06:31 PM
Stiff Shifter
Today while cruising around town I was finding it increasingly difficult to get the shifter into gear. I've never had this problem before. Does it need oil? I hope it's something that simple. If so, how do I check the oil, drain old oil, and refill? What type of oil do I use?
Thanks.
CB
Mark05059 06-01-2013 08:02 PM
check the fluid in the master cyl.. if its low then you have a leak that needs to be found.
CBinDC 06-01-2013 10:05 PM
Where is the master cylinder?
caoboy 06-01-2013 10:15 PM
Engine bay, driver side. Right by the brake master cylinder. Little reservoir.
CBinDC 06-01-2013 10:17 PM
The little silver (at least mine is silver) reservoir in front of the brake booster?
SuperMidget 06-01-2013 10:43 PM
it will be on the firewall beside/behind the brake booster.. something like this
http://image.jpmagazine.com/f/featur...angler+dry.jpg
caoboy 06-01-2013 11:27 PM
No, that'd be your brake master cylinder reservoir. You should check on that too while you're at it, won't hurt anything lol.
mudsweatNgearz 06-02-2013 12:02 AM
My shift lever gets stiff sometimes too. I need the wife to help me get it in the proper slot when that happens..lol.
CBinDC 06-02-2013 12:12 AM
Bazinga! LOL
CBinDC 06-02-2013 05:12 AM
1 Attachment(s)
That's what it's looking like. Any thoughts?
Attachment 633467
CBinDC 06-02-2013 05:16 AM
1 Attachment(s)
How does that look to you? Might as well ask while I'm at it.
Attachment 633468
befumo 06-02-2013 05:50 AM
Fill the clutch master cylinder before it gets too low and you have to bleed it out. Might be air in the line either way.
CBinDC 06-02-2013 05:56 AM
What do I fill it up with and how do I bleed it? By this do you mean drain the oil out first, then refill?
RustedWrangler 06-02-2013 06:26 AM
CB,
You should have an internal slave cylinder, so look underneath at the driverside of the transmission you will see a metal line (looks kind of like a fuel line) that has a fitting on the end, it sticks out of the bell housing a few inches.
Add fluid up top to the round reservoir in your photos (DOT 3 brake fluid).
You will need someone to help push in the clutch pedal while you turn the fitting to let out some air/bubbles. Just like bleeding brakes.
I would go ahead and change the trans fluid as well, I think you have the BA10 trans, if so here is a good write up.
http://www.jeepforum.com/forum/f12/h...ite-up-652142/
Joe100 06-02-2013 06:38 AM
Another thing.
Hi! All
I had the same problem so bad, the PO had broken the TC shifter knob right off and said he never moved it except 4 wd high and 2 wd never knew about theneutral and 4 wd low. I had to take the rubber boots off and use Kroil to barake it loose enough to be able to shift it and I've been lubing it every once and awile since no more shifter problems. Good luck to you Joe100:wave:
The time now is 02:17 AM.
