Sticky/ Stuck key ignition? - JeepForum.com
post #1 of 4 Old 06-20-2013, 02:18 PM Thread Starter
xlTravislx
This happened randomly, not slowly over time.
The problem is when I put my key in the ignition to start my 94 YJ not only is it increadabuly hard to physically turn the key but once I get it to turn to ignition it will stick. Ill have to push it back or else the starter will stay running.
Is there a spring or some kind of mechanism that pushes/ keeps the key ignition tight?
-White Jeep Club Member 231-
Replacing random parts on hunches spurred from other vehicles and peoples experiences with them is the safest bet.
xlTravislx is offline
post #2 of 4 Old 06-28-2014, 09:16 AM
UrsaVictrix
You get any more info on this? I've had that problem a couple times for an automatic 99 XJ and I'm scouring the forums for any info.. now the key is stuck in the ignition cylinder and I'm not sure what the problem is. Maybe its related.
UrsaVictrix is offline
post #3 of 4 Old 06-28-2014, 12:36 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Steering Column Help
Gentlemen: PM sent to you both, hope it helps you.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #4 of 4 Old 06-28-2014, 01:27 PM
UrsaVictrix
Turned out mine was just a key that was worn out. The other key is fine!
