Sticky Lifter - JeepForum.com
post #1 of 6 Old 12-08-2006, 07:01 PM Thread Starter
bulltrout
Sticky Lifter
Over the past few weeks I have noticed a little knock when at idle. I have traced it down to a sticky lifter in one of my back 2 cylinders of the 4.0. A mechanic friend of mine told my to try a little tranny fluid in the crankcase, otherwise it could get costly. I put in some Seafoam instead with a new oil change. I drove it about 1000 miles and it was still knocking. I did another oil change with more seafoam and am still getting the knock. Has anyone else had this problem? Any tips? If I need to get it fixed, how much am I looking at pricewise?
bulltrout is offline
post #2 of 6 Old 12-09-2006, 07:32 AM
Bret93YJ
You need to get that lifter out of your engine...it could damage your cam and then it gets costly. Lifters are relatively cheap to purchase from a parts store. All you need to do is take off your valve cover, crank the engine (watch out! this can get messy!), Isolate the lifter by listening and pushing down hard on the rocker arms while the engine idles. When you push down on your culprit lifter, the tick should get very loud. You'll know it when you hear it. Once you find your dud lifter, you can kill the engine. Then, remove that rocker and rocker arm and you should be able to see your lifter down in the hole. If it isn't completely mushroomed, you should be able to use a strong telescopic magnet to just lift it out, and then drop your new one in. If it's jammed, then you may have to get crafty. (The dealership uses a special lifter-extractor tool, but I'm sure it isn't cheap). Any how, when the old lifter's out, put the new one in, rocker arm and rocker back on properly,run the engine to make sure it runs right (a light lifter tick is to be expected until it settles), then put everything back in the proper order at the proper torque, wipe everything down, add oil if you need it, and you should be good to go. If your lucky, a 2-3 hour job. It'll cost you around $10 for the lifter and $8 for the valve cover gasket. Or you could just pay a trusted mechanic to do it and it shouldn't cost TOO much.
Hope that helps, and if I missed or overlooked anything I hope someone will let you know.
Bret
Bret Buchanan
'93 2.5L, RE 4" lift, 33" x 10.50s
Bret93YJ is offline
post #3 of 6 Old 12-09-2006, 07:46 AM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
great post! i'm sure MANY people have lifter tick and are unsure about how to fix it without paying a mechanic....
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #4 of 6 Old 12-09-2006, 11:08 AM
Mark_ZZ3
Mark_ZZ3's Avatar
Recalling some other posts. You can remove the lifter on a 2.5L without removing the head, but on a 4.0L, you need to remove the cylinder head to access the lifters.
Comments?
Mark_ZZ3 is offline
post #5 of 6 Old 12-09-2006, 11:16 AM
Jeeples
Jeeples's Avatar
Comments?
That is correct, however I thought I had seen it mentioned (again in previous threads/posts) that some people had managed to get them out without pulling the head. However I could be wrong on that part.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #6 of 6 Old 12-09-2006, 11:54 AM
xxxflhrci
xxxflhrci's Avatar
The holes in the 258/4.0 heads are only big enough for the pushrod to go thru. The head has to come off to swap lifters in these engines.
xxxflhrci is offline
Lifter tick, valve chatter, sticky valve..... brtt485 YJ Wrangler Technical Forum 28 09-28-2012 11:07 PM
Sticky Lifter?!?! SHADOE YJ Wrangler Technical Forum 3 07-26-2009 11:23 AM
sticky lifter weird ping sound comming from engine ZachAttack923 TJ Wrangler Technical Forum 0 07-19-2009 08:23 PM
Easy Way To Fix a Sticky Lifter Stiffler YJ Wrangler Technical Forum 10 03-18-2008 10:21 AM
sticky sticky brakes! jeep25tj TJ Wrangler Technical Forum 6 04-10-2007 09:56 PM
