Stereo cutting out when both wires to speaker are connected - JeepForum.com
post #1 of 10 Old 07-29-2015, 06:39 PM Thread Starter
iltl32
'94 Sahara
When I bought it only the speaker bar speakers worked.
The head unit had no aux. input so I replaced it with this one: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1. Nothing great but it should work.
After installation, I've got two problems
1. The right speaker (should be purple and purple/black wires) only works when the purple wire is connected to the head unit. If the purple/black wire is connected, all audio cuts out. At that point restarting the unit, pulling power cables, etc. will not restore audio. You have to unhook and rehook the purple wires after you unhook the purple/black to restore audio. What could cause that? Likely a faulty head unit or something else? As far as I know the other unit worked fine with both wires connected. The left speaker works fine with both wires connected.
2. Front speakers still don't work. Since they weren't working before I know it's probably not the head unit, but how do I troubleshoot this? I can't really trace the wires back because they're wrapped and re-wrapped into so many different things. What colors should I be looking for and is there a quick way to test the speakers?
The wires from the head unit are spliced into a plug. Here's a picture
http://imgur.com/97QyNzo
Both purple and purple/black wires are disconnected in that photo.
Any help is much appreciated. I really don't want to have to cut all the wires I just spliced so I'm hoping I can fix this without sending the unit back.
iltl32 is offline
post #2 of 10 Old 07-29-2015, 07:36 PM
DirtKar
Maximum Effort
DirtKar's Avatar
If you have a VOM you can look at the violet wires toward the speaker referencing ground. May be a short to ground in there somewhere.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #3 of 10 Old 07-29-2015, 10:35 PM
rustisexpected
Did you try hooking a speaker directly to the wires, off the back of the head unit, without going through the jeep harness?
If it works fine that way then you have a problem with your dash harness. And i would just run new wires instead of trying to troubleshoot the harness.
If hooking the speaker directly to the back of the head unit doesn't work. Then i would say you have a faulty head unit, or the pins to the head unit were positioned in the wrong locations. Either way i would send it back for a replacement.
rustisexpected is offline
post #4 of 10 Old 07-30-2015, 09:29 PM Thread Starter
iltl32
This is a great idea, I'll give it a shot this weekend. Thanks!
Follow-up question: I used those red crimp tube wire connectors so I guess I'll have to cut them off. Is there a removable connector I should be using? At this rate I'll be out of wire soon...
iltl32 is offline
post #5 of 10 Old 07-31-2015, 01:58 PM
rustisexpected
If you establish that everything is working properly then a "permanent" connection is fine. I always just solder and shrink tube my stereo. But I take the time to twist everything together and make sure its working before i plug in my soldering iron.
post #6 of 10 Old 07-31-2015, 02:36 PM
paulsadog
Originally Posted by iltl32 View Post
'94 Sahara
The black plug (c224 connector number in fsm wiring diagram) in your picture is the factory plug from the harness which normally plugs into the back of the stock radio. It connects both front and if installed the rear speakers. Also it supplies power, both constant (pink) and switched (red). Ground is supplied by another plug. The white plug is from an aftermarket install kit. It would be used to wire the aftermarket radio to the factory wired speakers and power. Is that what you are trying to do? You can get another aftermarker plug on ebay if you are running out of wire.
http://www.ebay.com/itm/271275284997...3AIT#vi-ilComp
paulsadog is offline
post #7 of 10 Old 07-31-2015, 03:00 PM
piotrsko
I was under the impression that purple with tracer was rear set and chassis was return for ground.
piotrsko is offline
post #8 of 10 Old 07-31-2015, 07:08 PM
paulsadog
I don't have the original radio and my ground does not have the original connector but the fsm shows a wire coming from splice s213 to the ground on the radio. Looks like a spade connector in the diagram. Also, diagram shows 1 purple (violet) in connector c224, no tracer, which is for right front speaker (+). There are 3 dark blue wires with tracers, DB/RD rt front (-), DB/OR rt rear (-) and DB/WT rt rear (+).
The rear speakers are connected at connector c227 which is, I belive, on passenger side, near the under dash light but that connector has a purple wire in it that connects to a LG/WT or DB/WT depending on if there are halo speakers or not.
I'm getting all of this out of a 1995 fsm and my 1993 jeep has the same color coding, so far.
post #9 of 10 Old 08-02-2015, 01:31 PM Thread Starter
iltl32
I got the rear speakers working. The splices were shorted in a couple places from previous owner.
Front speakers still do nothing. I looked at the passenger one and it has 4 wires connected; not sure what they're all form. Also the wire cases are so dirty/faded its kind of hard to tell the colors. I'm assuming their wires from the OEM plug to the aftermarket are not mapped correctly.
iltl32 is offline
post #10 of 10 Old 08-03-2015, 08:58 PM
rustisexpected
Honestly, I would just cut the factory wires behind the plug, solder in new wires, and route them across the dash to the speaker plugs.(I ran all new speaker wires, sound bar included) If you have an aftermarket set of speakers just add some spade connectors and plug them directly to the speakers. Just be sure you have the polarity correct. This way you avoid the funky factory wiring which was wired for your factory head unit, and not intended to work with a aftermarket replacement. Seems like less headache and much easier to troubleshoot in the future.
