Steering wheel vibrations - JeepForum.com
post #1 of 9 Old 11-12-2013, 01:05 PM Thread Starter
CBinDC
Driving around today, I noticed that the steering wheel was moving/ vibrating side to side every once in awhile. It didn't do it the entire time. The couple times it did it, it seemed quite noticeable. Ideas? Thanks.
CBinDC is offline
post #2 of 9 Old 11-12-2013, 01:44 PM Thread Starter
CBinDC
Also, the times when I noticed it, I had not hit a rut in the road. It was on a smooth surface. I'm wondering if there's a problem that needs to be addressed before I go flying over a highway embankment because my steering wheel suddenly stops working.
CBinDC is offline
post #3 of 9 Old 11-12-2013, 07:09 PM
superj
I would guess to just check everything for play and make sure no bubbles are forming on the sidewall of the tires
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #4 of 9 Old 11-12-2013, 07:18 PM Thread Starter
CBinDC
Thanks. I'll check it in the morning. What would the bubbles come from?
CBinDC is offline
post #5 of 9 Old 11-13-2013, 04:55 AM
SeanB95YJ
a defect in the tire, or hitting a bump (curb, pothole, etc) a bit too hard
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #6 of 9 Old 11-13-2013, 05:15 AM Thread Starter
CBinDC
That's one serious pothole!
CBinDC is offline
post #7 of 9 Old 11-13-2013, 10:19 AM
superj
sometimes it happens though, and it sucks once it really gets larger because you will be hopping all over hte road.
superj is offline
post #8 of 9 Old 11-14-2013, 01:55 AM
SunDevilJeeper
It could be wheel balance issues, could be steering components such as worn bushings, could be one of several things.
I'd go with what's already been mentioned in this thread, then check for missing wheel weights, then move to the steering components and inspect the tie rod and drag link.
1991 YJ: Daily Driver
1992 YJ: Pile of crap sitting in the garage.
SunDevilJeeper is offline
post #9 of 9 Old 11-14-2013, 12:40 PM
Peety
Check the tire pressures first, cold air is less dense than warm air, and it sure has gotten cold the past few days...
Peety is offline
