Steering wheel stick. - JeepForum.com
post #1 of 4 Old 12-17-2011, 01:21 PM Thread Starter
99XJBeast
I am looking for a replacement part number for the stick that controls high beams, turn signals, and wipers.. Mine is VERY loose and flimsy and is now snapped off..
What all do I need to replace to make it tight again, and work. My left turn signal would always get stuck on, and the right one I had to hold to keep the signal on...
Thanks.
7th jeep.Purchased bone stock on 3/05/13. Dark Red 2000 XJ. Automatic, 6.5inch Rough Country Long arms. 33x12.50x15 KM2s.
To be installed, grand cherokee alternator, durango steering box, currie steering. Then lockers
99XJBeast is offline
post #2 of 4 Old 12-17-2011, 01:41 PM
SunDevilJeeper
I had the same exact issue, got all spongy and then the arm broke off when I flipped it to signal a right turn.
I just pulled the assembly off an XJ at a junkyard, all the stuff looks the same so it should work. I haven't installed it yet.
1991 YJ: Daily Driver
1992 YJ: Pile of crap sitting in the garage.
SunDevilJeeper is offline
post #3 of 4 Old 12-17-2011, 01:57 PM Thread Starter
99XJBeast
I found 2 part numbers for auto zone, just can't find the actual lever itself.. Anyone have a number for it?
http://www.autozone.com/autozone/par...0473_179670_0_
post #4 of 4 Old 12-17-2011, 02:25 PM
DAVE4273
I found them just hanging on the shelf in autozone. Its the exact replacement part for it. Go figure... 9 bucks too. Without cruise control of course.
David
DAVE4273 is offline
Steering stick PotentialYJNewb YJ Wrangler Technical Forum 10 08-19-2011 10:53 AM
steering wheel leather peeling away... what should I do? mexi-chain steering wheel? LiveAndLearn TJ Wrangler Technical Forum 29 05-19-2011 04:10 AM
4 wheel driver stick shift hguffman YJ Wrangler Technical Forum 8 07-21-2004 08:48 AM
How far will this Tire/wheel combo stick out?? ZJEEPSTER TJ Wrangler Technical Forum 3 07-05-2004 08:19 PM
Noise from stick shift area, and Steering wheel itchyandscratch TJ Wrangler Technical Forum 3 10-05-2002 08:28 PM
