steering wheel disconnect? - JeepForum.com
post #1 of 5 Old 03-04-2009, 03:58 PM Thread Starter
Anonymous6915
2009 JK Wrangler
ok so i was just looking around and iv always like a quick disconnect steering wheel(security purposes) i know that if someone really wants it they can get it but at least it would slow them down a bit.
I know grant makes a kits thats about $150 but what about something like this;http://offroad-review.com/new/index.php?page=175
im interested to see if anyone has tried something like this on a YJ...
thoughts?...
Anonymous6915 is offline
post #2 of 5 Old 03-04-2009, 04:46 PM
ghost183
i used to have the grant system on a CJ i had, very nice system, but tempermental to dirt and water, the release lever would sometimes have to go back and forth a few times to disengage the lock and allow the wheel to come on, or go off, i found itwas best o keep it spotless and even used emery clotch to brighten it up than use WD or PB to lube it, they just attracted dirt even faster..
but once on, was very secure.. just a slight ticking noise when you pull it left and right, its not a 100% solid mount so it had a small amount of side play
edit:
and oh, my horn NEVER worked right after i installed it, a few occassions didnt work at all, and sometime i got that "beep, beep, beep" as i tirned the wheel!!
it would even start blaring on its own and i would have to jump out and pull the clip on the horn itself till i installed a dash mounted horn button..
Important Notice:... DUE TO RECENT BUDGET CUTS, STOCK MARKET PERFORMANCE, RISING COST OF ELECTRICITY, GAS AND OIL... THE LIGHT AT THE END OF THE TUNNEL HAS BEEN TURNED OFF.... WE APOLOGIZE FOR THE INCONVENIENCE............ Regards:... THE GOVERNMENT
ghost183 is offline
post #3 of 5 Old 03-04-2009, 05:13 PM Thread Starter
Anonymous6915
2009 JK Wrangler
thanks for the input but i was more interested in seeing if anyone used the one in the link...
post #4 of 5 Old 03-04-2009, 06:06 PM
1 ton yj
1 ton yj's Avatar
thoughts?...
I use one like that but with the splines not the hex. The hex has a lot of play in it whereas the splined ones are tighter. I always weld them on but if you don't want to be that committed I believe Summit sells one manufactured by Grant that threads on to the column.
1 ton yj is offline
post #5 of 5 Old 04-01-2010, 01:15 AM
lyleorszulak807
1988 XJ Cherokee
I have been looking at this as well for my XJ, after some a hole tried to steel it last night I am looking for some theft protection...
Ive seen one on jegs for 80 bucks, it says for GM saginaw type shafts. I imagine thats the one which would fit nicely over the splines..atleast thats what the research I did points out to. With that one you dont even need to weld it, just cage nut.
But I have never seen or used the one in the link...
88 Jeep Cherokee 4.0L - RE 5.5" springs | Teraflex shackels in the rear | RE1660 HD track bar with drop bracket | Rock Krawler adj UCA/LCA
ROLLED & TOTALED! 89 XJ 4.0L Renix AW4 | Rustys Air intake kit Steering Box reinforcement bar Bomb proof Motor Mounts | RE HD Track Bar, drop down Bracket, support brace | Cobra 75sxt CB | 33x12.5x15 MTR's on Crager soft 8 | Teraflex and 5.5" RE HD springs | yada yada...[/CENTER]
lyleorszulak807 is offline
Installed new steering gear - Steering wheel turned? JasonJW TJ Wrangler Technical Forum 1 10-11-2009 10:15 PM
Need sway bar disconnect in two-wheel drive OJEditor JK Wrangler Technical Forum 13 08-03-2009 08:46 AM
Do wheel spacers make your steering wheel wobble at high speeds? bgndobe TJ Wrangler Technical Forum 22 07-20-2009 08:27 AM
PROBLEM: Vehicle/steering wheel/back right wheel shake badly. Black99ac TJ Wrangler Technical Forum 5 10-11-2007 12:41 PM
Steering Wheel Disconnect Help Activ8Potential TJ Wrangler Technical Forum 10 06-17-2007 01:53 PM
