steering stop bolts - JeepForum.com
post #1 of 4 Old 01-16-2011, 09:02 PM Thread Starter
huntinfish
steering stop bolts
I am new to the jeeping world. I have an 88 yj wrangler. it has a 2.5 body lift and I put a set of 32X11.50X15 tires on it. They rub when you turn the wheels all the way. I have researched my options via this forum. I have decided(mainly because of budget issues) to adjust my steering stops. This is the problem. I don't really have a complete understanding of how this works. I think I have located them. On another post someone said to just pull them out and put a couple of washers on them. The bolts that I located look like they are already out about 3/4 of and inch. so obviously I don't need to put washers on this. Someone please enlighten me as to how I need to adjust this. Do I just back them out even more? They are seized up pretty good right now.
huntinfish is offline
post #2 of 4 Old 01-16-2011, 09:15 PM
HumbertUSAF
You just back them out even more. The washers you add are just to keep them from turning back in and most times the jam nut that you would screw up against the knuckle to hold the bolt out is seized and wont move so just add washers accordingly until the bolt is out far enough to stop the tire where you want it to stop
Active Duty United States Air Force - Tactical Aircraft Maintenance
Air Force Jeep Club Member #88
HumbertUSAF is offline
post #3 of 4 Old 01-16-2011, 09:25 PM
Xtremjeep
Most have a tack weld on them to keep them from turning. You will have to grind it off before adjusting.
Build Thread:
1980 CJ-7 Mall crawler (RIP 2010)
1983 CJ-8 Scrambler Full resto in progress
1988 YJ Fully Built but never Done
Xtremjeep is offline
post #4 of 4 Old 01-16-2011, 11:12 PM
Old4X
1990 CJ7
On mine the tack weld locked the jam nut onto the bolt. The bolt still came out easiily.
Use washers, or buy a couple new longer bolts and jam nuts.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
steering stop bolts - what size? ElementX TJ Wrangler Technical Forum 2 01-08-2011 09:03 PM
tj steering stop bolt jetguy81 TJ Wrangler Technical Forum 1 09-28-2009 03:15 PM
Steering Stop Pipedrummer TJ Wrangler Technical Forum 2 02-13-2007 11:56 AM
front bump stop bolts benbrewbeer TJ Wrangler Technical Forum 3 10-25-2006 02:24 PM
Steering stop adjustment raStapiMpjaY YJ Wrangler Technical Forum 3 09-14-2006 10:56 PM
