Steering stick - JeepForum.com
post #1 of 11 Old 08-08-2011, 06:06 PM Thread Starter
PotentialYJNewb
1987 YJ Wrangler
Steering stick
Hello fellas. Seems like I have a billion threads up but so many questions, agh.
Anyway, I was wheelin the last two days a bit, and the steering was never good from the start, in fact my Jeep symbol sits facing the passenger in the center column of the steering wheel which leads me to believe I need a new steering column.
Anyway, when I'm driving, especially if I rev around ~3k rpm or more without shifting, there's really a noticeable stick in the steering and for a second the car won't steer in any direction and will remain stuck. Usually if I shift it, it will correct it, but will start again on the next gear. It's actually a real workout to keep this thing smooth on the road. Any ideas?
I do need to get new springs and shocks soon, as some of us already determined.
PotentialYJNewb is offline
post #2 of 11 Old 08-08-2011, 06:16 PM
jbeebe
have you changed the power steering fluid? it's super easy to do and corrected my steering "stick", even when i thought i would have to replace the whole pump.
jbeebe is offline
post #3 of 11 Old 08-08-2011, 06:22 PM
Hillbilly Jeep
power steering fluid..has the colume been apart? have u sprayed down the stearing shaft with anything?
Hillbilly Jeep is offline
post #4 of 11 Old 08-08-2011, 08:16 PM
TheNewbie
Nope. You don't need a new steering column. You just need to adjsut the drag link. Read here...
http://www.4x4xplor.com/alignment.html
That will get your steering wheel re-centered. And as far as the "stick", I'd try to flush the fluid and rebleed it. Then you can move on from there is that doesn't help.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #5 of 11 Old 08-08-2011, 08:45 PM Thread Starter
PotentialYJNewb
1987 YJ Wrangler
Will do. Thanks for the input.
post #6 of 11 Old 08-08-2011, 08:54 PM
TheNewbie
Keep us posted if flushing the fluid and bleeding it doesn't work.
post #7 of 11 Old 08-09-2011, 12:42 PM Thread Starter
PotentialYJNewb
1987 YJ Wrangler
Where can I find a cheap siphon device to flush all the fluid out?
post #8 of 11 Old 08-09-2011, 12:52 PM
TheNewbie
If you've never done it before (which it sounds like you haven't) you should research this a bit. It's easy to do though. And it will be a good learning experience.
Do you have a book for your Jeep? Like a Haynes or Chilton? That will guide you through it. You are baically going to bleed the system, but keep going until all of the fluid has drained and been replaced.
I'm really not trying to be a smart @** with this link even though most people use the "let me google that for you" links to be a prick I really just figured it would help.
http://lmgtfy.com/?q=how+to+flush+steering+fluid
Read a few of those pages and watch a few videos. Also, if you don't have a book... get one!
post #9 of 11 Old 08-18-2011, 08:00 AM
dfnp
2012 WK
PotentialYJNewb delete some pms so i can message you about rim purchase. says your mailbox is full.
dfnp is offline
post #10 of 11 Old 08-19-2011, 10:30 AM Thread Starter
PotentialYJNewb
1987 YJ Wrangler
I deleted all of it you should be able to pm me now
post #11 of 11 Old 08-19-2011, 10:53 AM
dtn8tr
Except that on the YJ you will have to disconnect it from the pitman arm because the tie rod end screws into the dragllink, not a turnbuckle.
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
oil stick-- not going in...?? branjmb YJ Wrangler Technical Forum 4 03-23-2011 11:48 AM
Did the LJ come in stick? MattJeep TJ Wrangler Technical Forum 19 03-01-2011 03:16 PM
OME Steering Stabilizer Installation Parts (06 TJ 4Cyl Stick) Homcy TJ Wrangler Technical Forum 10 10-24-2010 01:20 AM
Need Help: Wiper Stick broke.. need to know how to remove steering column sdoffroad YJ Wrangler Technical Forum 6 01-23-2009 06:30 PM
Noise from stick shift area, and Steering wheel itchyandscratch TJ Wrangler Technical Forum 3 10-05-2002 08:28 PM
