Steering Shaft and Bearing Replacement - JeepForum.com
post #1 of 7 Old 11-17-2008, 09:14 PM Thread Starter
ech0sh4y
2008 WK
Well after putting on my suspension lift and my body lift I found out that my steering shaft does not collapse or expand anymore ( i think it is suppose to) and my lower bearing has come out of the bottom of the firewall column (if that makes sense). So my question to you fellas is, what is a decent replacement steering shaft? One that will accomidate the new bodylift and some minor flexing (daily driver weekend wheeler). Also how does one get the old bearing off the bottom off the upper shaft? Is it pressed on? Or do you have to heat it up and beat it? Take the whole steering column out?
Thanks in advance!
~ Brian
2008 WK Overland CRD
ech0sh4y is offline
post #2 of 7 Old 11-17-2008, 09:33 PM
azgurney
You should be able to reuse your steering shaft. It is just rusted together at the slip joint. Remove it and take it apart. Clean the slip joint and lube it. Are you saying just the inner bearing race is still on the steering column? The bearing will slide off of the steering column without heat or major force. Try spraying some penetrating oil on it. I got my replacement bearing from Quadratec. To get the steering shaft off completely remove the bolts on the u-joints and use a large chisel driven in the slot to loosen the grip so it came be slid off the shaft.
91 Wrangler 4.0 5sp
8.8 4.10 explorer axle, 33x12.50x15 x-terrains,Rancho 2.5 lift and shocks, Goforit 1" motor mount lift, 1" body lift, sailcloth top with tinted windows
azgurney is offline
post #3 of 7 Old 11-17-2008, 09:38 PM Thread Starter
ech0sh4y
2008 WK
Well i can get my old shaft out... it put it under a post-lift at work and it won't slide at all! so the shaft is welded together. I didn't really try getting the bearing off as I was more concered about the steering shaft. i just didn't know if you had to pull the whole steering column out or not to change the bearing. Thanks!
~ Brian
ech0sh4y is offline
post #4 of 7 Old 11-18-2008, 07:55 PM Thread Starter
ech0sh4y
2008 WK
Does anyone have any experience with flaming rivers steering shafts?
~ Brian
ech0sh4y is offline
post #5 of 7 Old 11-18-2008, 08:47 PM
navman
I just replaced mine when I did the durango box upgrade. My shaft was rusted solid. If you heat it up good with a torch you should get it loose. Mine came loose, but I decided to replace the shaft since my ujoints when junk as well. I went with a borgeson shaft. Much beefier than stock and better ujoints. They are in Torrington CT, but I believe quadratec has them as well as any keystone dealer can get them. $275 range.
95 YJ 5.0 linked etc
navman is offline
post #6 of 7 Old 11-18-2008, 09:07 PM Thread Starter
ech0sh4y
2008 WK
Would it work with a 1" bodylift?
~ Brian
ech0sh4y is offline
post #7 of 7 Old 11-18-2008, 09:09 PM
navman
It should, but you could call them for the exact specs, and they can make a custom one if needed, just a longer inner shaft.
navman is offline
Lower steering shaft bearing replacement - With pics! Fernando YJ Wrangler Technical Forum 91 04-29-2016 09:38 AM
Anyone ever replaced a steering shaft bearing? MR.CLIFFORD TJ Wrangler Technical Forum 4 08-19-2009 08:33 PM
steering shaft bearing play scherb53 YJ Wrangler Technical Forum 3 08-27-2008 09:11 PM
Input shaft bearing replacement Gomofast TJ Wrangler Technical Forum 5 07-30-2008 06:42 AM
steering shaft bearing??? jipjip YJ Wrangler Technical Forum 2 01-25-2006 06:03 PM
