steering question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > steering question
Steering and more from Ruffstuff!The Ruffstuff 14 Bolt Complete Swap Kit!Ruffstuff Axle Simple Swap Kit!
Unread 12-08-2005, 11:05 AM   #1
JOKER4INK
steering question
I am running spring under right now. In the spring, Im gonna ditch my 4" springs, and go 1.5" and sprung over. My question is, do I have to run high steering, or will the existing steering linkage work?
88 YJ...kinda. Clayton Hard Arms, V8, 1 tons running gear, twin sticked, Irok's, fuel cell, multi-colored
JOKER4INK is offline   Reply With Quote
Unread 12-08-2005, 11:23 AM   #2
atomicmoose
Just call me Moose
atomicmoose's Avatar
You may get some bump steer since the drag link and the tie rod will be father out of parallel. You should definitly consider a high-steer setup for SOA.
atomicmoose is offline   Reply With Quote
Unread 12-08-2005, 11:24 AM   #3
JOKER4INK
with the stock steering linkage be in the way of the springs?
Unread 12-08-2005, 11:49 AM   #4
superjoe
yes actually it will be in the way
if your still running a D30 get a passanger side steering knuckle off of a WJ, it has a seperate leg that comes off of it higher up that allows for the drag link to mount above the springs and that way you wont ahve to worry about alignment like wiht MOST highsteer set ups, you will just need to to get a longer drag link.
Joe Clark † 210-639-0276
/l ,[____], 82 CJ 8 Scrambler Currently all stock but that will change.
l---L--0lllllll0- Christian 4x4.com
()_) ()_)----)_)
superjoe is offline   Reply With Quote
Unread 12-08-2005, 11:55 AM   #5
atomicmoose
Just call me Moose
^^ Good point.
Found this for you, Joker
http://www.americanjeepers.com/artic...ion-for-YJ%92s
Unread 12-08-2005, 11:59 AM   #6
superjoe
yep that is EXACTLY what i was talking about
()_) ()_)----)_)
Unread 12-08-2005, 12:01 PM   #7
atomicmoose
Just call me Moose
I got your back, Joe.
Unread 12-08-2005, 05:15 PM   #8
JOKER4INK
Thanks for the link. Im going to check it out. Now, heres another question for ya. How about on a 44? When I swap in my 44's in the spring, would I have to do the same thing, or is that just on the 30 up front?
Unread 12-08-2005, 05:25 PM   #9
superjoe
with the D44 you will want to go with a High steer set up also but wiht it you can get kits to put both draglink and tierod up top of the springs
()_) ()_)----)_)
Unread 12-08-2005, 05:27 PM   #10
JOKER4INK
Joe, you're the man!
