Steering pulsing - JeepForum.com
post #1 of 3 Old 05-06-2002, 07:32 AM Thread Starter
rick_chicago
Steering pulsing
I'm noticing some pulsing in the steering I can't quite chase down. It's very light, but it is there.
I'm also noticing a rough idle that seems to be associated with it, as if there's just a little extra load being placed on the steering system.
I went ahead and replaced the power steering pump and belt (pump was original, and it's an 89!).
I'm going to check tire pressure again, but that wouldn't cause the idle problem, so I'm betting against that. I'm also going to check belt tension again - but my last check showed the appropriate 1/4 inch play in the belt, so I'll be surprised if it is that.
Any ideas what else it could be?
89 YJ 2.5L 5-Spd
rick_chicago is offline
post #2 of 3 Old 05-06-2002, 09:42 AM
ezgoing
ezgoing's Avatar
My friend had a pulse in his steering at one time and it ended up being that a balance weight on one of his tires came off. You may want to check that though I don't see that affecting the idle.
Hope that helps.
'92 YJ Sahara
1 1/4" shackle lift for now soon to be some sort of lift
31" Bridgestone Dueller A/Ts on AR-767 wheels
'67 Ford Galaxie 500 (passes everything but the gas station)
"What do you mean I can't make it, watch me!" = oops
ezgoing is offline
post #3 of 3 Old 05-07-2002, 07:14 AM Thread Starter
rick_chicago
Well, I'm beginning to track this problem down.
A check again last evening showed low fluid in the power steering resevoir. I topped it off, and it seemed to help. Of course, it also seemed to pop up again today.
I'm now thinking I have a leak in the power steering system, although I can't seem to find any visual proof (no puddles).
Does anyone know if it could be the pressure switch on top of the pump?
I'm now thinking I should have just replaced it as well.
89 YJ 2.5L 5-Spd
pulsing vibration at 70+ mph sportcoupe TJ Wrangler Technical Forum 60 12-11-2016 10:11 AM
Pulsing vibration at 60+mph BoarderX47 TJ Wrangler Technical Forum 7 11-22-2012 01:27 PM
engine pulsing cosmo_j YJ Wrangler Technical Forum 18 12-29-2009 10:21 AM
Pulsing Vibe from 50-60 mpg missionAvs TJ Wrangler Technical Forum 10 12-03-2009 11:01 PM
"Pulsing" Steering Wheel During Slow Turns Hamish TJ Wrangler Technical Forum 6 06-28-2008 09:01 AM
