steering problems 92 yj - JeepForum.com
post #1 of 11 Old 08-31-2011, 05:22 PM Thread Starter
33tjbogger
hey everyone i have a 92 yj with 3.5 bds lift and bds 1" boom shackle lift everything is brand new all bushing everything i still have trac bars in front and rear with new poly bushings. well my jeep is all over the road and dont now what it could be can anyone help me out. thanks
33tjbogger is offline
post #2 of 11 Old 08-31-2011, 07:26 PM
rustybeater
What is it doing is it pulling feeling like body roll in turns are you getting a wobble or a hop?
rustybeater is offline
post #3 of 11 Old 08-31-2011, 07:32 PM Thread Starter
33tjbogger
no hopping its pulling like crazy side to side cant keep it in straight line down the road look like im driving drunk down the road swerving. i dont have any body roll either. my wheel bearings are tight too and my tir rod ends are tight not loose at all
post #4 of 11 Old 08-31-2011, 07:57 PM
glenn-91YJ
glenn-91YJ's Avatar
So I take it the Jeep didn't exhibit this problem prior to the lift. Are you running the same tires?
I installed a 4" RCD lift with 3/4" booms and didn't have any major problem. I did install an extended pitman arm to drop the drag link. Very small bump steer if i hit a good size bump above 40 mph or so. Running 33x10.5s.
Could be the lift is exaggerating bad tie rod ends, ball joints or wheel bearings. Easy enough to check those and go from there. Make sure you did not torque down the shackles and track bars before putting the weight of the Jeep back on the ground. You need to let everything settle in before you torque things down.
Owning a "Renegade" means being "Different"!
"The greatest danger to American freedom is a government that ignores the Constitution."
-Thomas Jefferson
glenn-91YJ is offline
post #5 of 11 Old 08-31-2011, 07:59 PM
glenn-91YJ
glenn-91YJ's Avatar
When you reattached the track bars did the lift come with relocation brackets? You can't put it back in the stock location or you'll throw your axle positions off.
-Thomas Jefferson
post #6 of 11 Old 08-31-2011, 08:32 PM Thread Starter
33tjbogger
im running 31" pitbull growler tires my kit came with relocation brackets for the track bars and not i did not torque the track bars or the shackles before i set it on the ground. it has brand new ball joints and wheel bearings. and the steering is tight.
post #7 of 11 Old 08-31-2011, 08:41 PM
Castr8r
Have your alignment checked and ditch the track bars. Check the steering box for play.
I've been throwed out of a carwash- too much mud!
I've done bodywork useing a winch, a tree, a prybar, and a BFH!
Now, my wild oats have turned to prune juice and all-bran...
Castr8r is offline
post #8 of 11 Old 08-31-2011, 08:47 PM Thread Starter
33tjbogger
ok with track bars out its not going to make it wonder more is it? ill check steering box for play
post #9 of 11 Old 08-31-2011, 09:06 PM
northernsimon
got a buddy? get him to hop inside the jeep and turn the wheel, watch the steering shaft go into the steering box. if the pitman arm moves instantly. the box isn't your problem.
sooooo..what could it be? honestly, i'd put money on the steering shaft. the u-joints wear, and there's play.
other things to check? sticky ball joints/ bad tie rod ends and alignment (toe-in?) . but really, spend $100 on a steering shaft..............
northernsimon is offline
post #10 of 11 Old 08-31-2011, 09:45 PM
jonpin
I had a steering problem with my 89 wrangler and my problem was the drag link at a bad angle let me refer you to my old thread I have videos too http://www.jeepforum.com/forum/f12/s...rning-1234030/ jb4x4 high steer was what i needed my tie rod ends where fine was nothing to do with tie rod ends just letting you know if you read the thread it came up alot. hope it helps might not.
jonpin is offline
post #11 of 11 Old 08-31-2011, 10:13 PM
SpikesHD
1987 YJ Wrangler
Alignment!
Put the front wheels 1/16th to 1/8th of front toe-in and you'll be golden.
Toe out SUCKS!!!!!! All over the place.
Edit:
Like previous answers have stated - your track bars need to be GONE and your steering geometry needs to be as parallel from the front as possible.
Si vis pacem, para bellum.
SpikesHD is offline
Steering Problems - Wondering Steering. OH92 TJ Wrangler Technical Forum 6 11-18-2010 07:01 AM
Steering Problems RogueSpear2023 TJ Wrangler Technical Forum 3 03-02-2009 08:54 PM
89 Steering Box Problems CricketKilla YJ Wrangler Technical Forum 6 02-06-2008 07:31 AM
I am having steering problems kaffeene YJ Wrangler Technical Forum 5 10-18-2005 06:37 AM
Steering problems 90yjwrangler YJ Wrangler Technical Forum 0 11-14-2004 08:43 PM
